      • Japan
      • Vietnam
Project Videos
  • Project Videos
Project Videos
Documents Massive Raspberry Pi -- Episode 507
  • Date Created: 13 Jul 2021 7:33 PM Date Created
  • Last Updated Last Updated: 16 Jul 2021 7:24 AM
  • Views 3728 views
  • Likes 8 likes
  • Comments 11 comments
Way back in 2019, element14 hosted the PiCasso Design Challenge, challenging our members to use the Raspberry Pi Model 3 B+ to create masterpieces or works of art.  What would be more meta than a work of art based on the Raspberry Pi 3 B+ than a Raspberry Pi 6 times it’s actual size?  And it’s not just art. . .  the USB connectors may not be functional at 6x size, but all the GPIO pins function - and are driven by a Raspberry Pi.
See the entire blog series Wesley created while working on this project: https://www.element14.com/community/community/design-challenges/picasso/blog/authors/gam3t3ch
Bill of Material:
Part Manufacturer Quantity
Raspberry Pi 3 Model B+, BCM2837B0 SoC
Raspberry Pi 1 Buy Now
element14 presents
element14 presents  |  About Wesley | Project Videos
  • raspberry pi
  • e14p_WG
  • game3t3
  • wesley
  • e14presents_game3t3
  • friday_release
  • mayermakes
    mayermakes over 4 years ago +4
    I wish I had a wall suitable to hang up something awesome like this!
  • davedarko
    davedarko over 4 years ago +4
    If you ever have to move, you need to get a box printed great project, happy to see that it made it into a Friday episode!
  • kmikemoo
    kmikemoo over 4 years ago +3
    That is truly awesome!!! The detail is amazing. Even if it wasn't functional, it would be brilliant. But it is... mind blowing. <thumbs up>
  • davedarko
    Did you decide on a scale or did you "just" start with a 20x32 board? I made this little table and got a bit confused image
    yxrationormal pi mm56851,52wes inch20321,60wes mm508812,81,60scale per axis11,0210,46
    I assume you started with a 20x32 board that fits your CNC and then projected something scaled onto it?
  • gam3t3ch
    gam3t3ch over 4 years ago in reply to davedarko
    correct so the pi was the max I could cut on my cnc safely without extending my bed and using more time.  my mpcnc is 2ftx4ft but actual usable is just under that.  I also think it ended that size as well due to the scale of a few of the parts on my 3d printer which my plate is only 220mmx220mm.   But yes it was due to limitations of the machine it ended at that exact size. and on the cnc there is the outer cutout on the cnc that took a bit of the size away as well. which was over 12mm in total if I recall correctly.
  • gam3t3ch
