The Electronics Inside
  • The Electronics Inside
Forum Dimmer Switch Tear-down
Join The Electronics Inside to participate - click to join for free!
  • Subscribers 51 subscribers
  • Views 2042 views
FerroMag
FerroMag over 3 years ago
An inexpensive dimmer switch for home lighting on offer at any home improvement center is more than a variable resistor.  Unboxing it, there are a couple of capacitors, a BTA12 600B TRIAC, a delightful little inductor coil, and some other odds and ends. Could you give us a tour and a circuit diagram explaining how it all comes together?
  • colporteur
    colporteur over 2 years ago +1
    I had to go do a search to recall someone did a tear down of a dimmer before. What's inside a 20+ year old dimmer switch? scottiebabe has always been a top shelf contributor to the community. I'm not…
    dougw over 3 years ago
    You could ask Dave Edwards ( a531016  ) to do a teardown on element14 Presents.
  • a531016
    a531016 over 3 years ago in reply to dougw
    There are lots of different types of dimmer designed to work wit different load types, variac, triac, trailing edge leading edge etc. It could make a good episode if anyone is interested?
  • kmikemoo
    kmikemoo over 3 years ago in reply to a531016
    If there are lots of types... I'm interested.  I figured that they were all the same since all that I have seen have the same 600w limit.
  • tp86
    tp86 over 2 years ago in reply to a531016
    Hi mate. Yesterday I watched your youtube video on the wm-ex631 teardown. It was very interesting. I unfortunately need to replace or at least probe to diagnose my hold spdt switch. To do this I need access to the mainboard on the side the tape cassete goes. I was wondering if you managed to get access to this side of the mainboard without soldering out the many solder pins that the service manual suggests to remove the mainboard (Ideally I didnt want to desolder as I do not have the tools).  Many thanks in advance for any advice. Kinds regards. Tom P
    Reference video:  www.youtube.com/watch
  • colporteur
     scottiebabe has always been a top shelf contributor to the community. I'm not sure if this is what you had in mind.
