The Electronics Inside
  • The Electronics Inside
Documents HP ProLiant DL360 G6 Teardown and Maintenance -- The Electronics Inside 58
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 9 Jun 2022 2:47 PM Date Created
  • Last Updated Last Updated: 13 Jul 2022 7:24 AM
  • Views 26715 views
  • Comments 10 comments
I needed to do some maintenance on some kit at home. So of course I thought I'd bring you along for the ride! Here is my 1u server that I use for rendering videos.
Supplemental Content:
element14 presents
element14 Presents  |  About David |  Project Videos  |  The Electronics Inside
  • computing
  • david
  • 1u
  • Rack Mount
  • server
  • teardown
  • the electronics inside
    beacon_dave over 4 years ago in reply to a531016
    "...Uplink communications is via S-band (16-bits/sec command rate) while an X-band transmitter provides downlink telemetry at 160 bits/sec normally and 1.4 kbps for playback of high-rate plasma wave data..."
    https://voyager.jpl.nasa.gov/mission/spacecraft/
  • colporteur
    colporteur over 4 years ago in reply to DAB
    I did a brief stint supporting PDP-11-04 used for generating targets on air traffic control displays. Blue & Gold with their call signs sporting a row of switches across the front for programming.
  • a531016
    a531016 over 4 years ago in reply to DAB
    Thanks DAB, great to hear from you!
    1 dollar per word - that's incredible to imagine... And to think that was still a significant improvement over manual labour or claculation to be worth it.
    Another great comparison a remeber hearing, I seem to remember the Voyager probes could communicate at about 8 bps, which was comparable to a good telegraph operator!
    DAB over 4 years ago
    Another great teardown.
    The first computer system I worked on had four racks for the PDP-11-20 computer and four racks of special build electronics for capturing digitized images generated by a laser system.
    As for memory costs, we upgraded to an additional 8K by 16 bits of core memory for about 8,000 USD. That was 1 USD for each 16 bit word.
    Later we got an additional 2.2 MB disc drive with one 1.1 MB removable platter. Great upgrade from our original 64 KB hard drive.
    How times have changed over the last fifty years.
  • a531016
    a531016 over 4 years ago in reply to ralphjy
    That's a tough call to make. And I have never heard of anyone saying thank you for risking keeping it up, or thank you for being safe and shutting down eaither....
  • ralphjy
    ralphjy over 4 years ago in reply to colporteur
    It does bring back memories.  We were a small remote engineering design office and we maintained our own servers.  When we did an upgrade to standardize the hardware I took home one of the old racks.  Of course, it was 7 foot tall with power strip, cable trays, and fans - so I had to disassemble it and reassemble it in my computer room over the objections of my wife.
    I have fond memories of the automated sensor calling me in the middle of the night because the server room was overheating.  When we had power outages it would knock out our AC, but our UPS backup would keep the servers alive to protect overnight runs.  So, it was a judgment call to shutdown.
  • colporteur
    colporteur over 4 years ago in reply to a531016
    Stop it, I'm getting all teary eye'd. My wife had other ideas when I suggested a rack for my computer room. All I managed to keep was the 5ft log power bars for the work bench.
  • a531016
    a531016 over 4 years ago in reply to colporteur
    I didn't realise I had some photos from 2015!
    Tape Rack and Carosel
    Tape Handling Robot
  • a531016
    Thank you for sharing your experiance, there are some interesting points that you raise in here that I am hoping I get to cover in a field trip style "The Electroncis Inside", If I can get the paperwork and red tape all tied up!
    I briefly got to work on the power in a TV Broadcast suite. There was a shared comms room for all the equipment that needed high up time and resiliance. The site had 4 different power systems to each rack! It was just at the time they were decommissioning and removing the old tape autoloader "robots". I wish I had been allowed to take some of those home for a future "TEI" episode!
  • colporteur
    Just some personal insight into the hardware you are using.
    Proliants were used extensively in Microsoft Mediaroom streaming television. I worked for an ISP that provided television to 160K subscribers using Mediaroom. A server farm to ingest, encrypt and distribute the content could exceed 200 servers. 1U's and 4U's server sizes were typically along with numerous storage arrays similar to the unit you showed.
    If being used to stream video content is any indication of its performance your choice to use it for rendering has some merit.
    The beasts are noisy! You would typically leave a server room to carry on a conversation. I had one in a lab in my basement. I gave it up or turned it off when not in use because of the fan noise.
    Heating and cooling for our operation were done via Infinite Access (IA) flooring. The floor was sealed except under the racks. Cool air was pumped under the floor space, typically 18inches of free space and exited the top of the rack. All cables came up from under the floor.
    Anchors rods would be secured from the rack into the flooring below. Pulling a few servers out of the rack could cause it to come crashing down on you if it wasn't anchored to the floor.
    Most monitoring of the servers was performed using SNMP protocol. Vendors invest heavily in using SNMP MIBs to get information from the server to a monitoring host. To get the most out of monitoring using the vendor MIbs was critical.
    I have personally hot-swapped both power supplies and hard drives without an outage. As you are changing a drive thinking, is this going to take out a channel on the guide was a little unnerving.
    Maintenace was done between the hours of 01:00-06:00 to prevent interruptions other than the customers watching porn:)
    Thanks for a trip down memory lane. At my age, everything is from memory lane.
