The Electronics Inside
  • The Electronics Inside
Documents Retro(1G) vs Modern(4G) Cellphone Teardown -- The EIectronics Inside 07
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 27 Aug 2019 3:48 PM Date Created
  • Last Updated Last Updated: 11 Sep 2019 7:24 AM
  • Views 1822 views
element14 presents
element14 Presents  |  About David   |  Project Videos  |  The Electronics Inside
We compare the inside of a 1988 1G carphone to it's 2013 great grand child. Other than a big color screen, what else has changed? We tear both down to take a look.
  • analogue cell phone
  • car phone tear down
  • 1g mobile phone
  • e14presents_davidedwards
  • the electronics inside
  • a531016
    a531016 over 7 years ago in reply to celcius1
    Good (and sensible logic) for the additional wire, but not quite! A commenter on YouTube has correctly stated the answer, although he appears to have worked for the manufacturer, so it was cheating a little!
  • celcius1
    celcius1 over 7 years ago
    That fourth wire if it was used in a car type situation follows a standard scheme, black for ground, yellow for constant 12v and red for switched, the purple wire is the sound output for connection to the right hand speaker in the car, with the ground attached to the black wire.
    If this is a car phone as stated, then that would be the colour scheme that fits as that is the standard colour scheme followed on all aftermarket car equipment from the early 80’s onwards, if you trace the purple wire back you will find it’s coming from the audio output.
