The Electronics Inside
  • The Electronics Inside
Documents Console Showdown! - Original PSP Vs. Vintage Nintendo Game & Watch -- The Electronics Inside 10
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 22 Oct 2019 7:52 PM Date Created
  • Last Updated Last Updated: 7 Jul 2021 7:24 AM
  • Views 1743 views
element14 presents
element14 Presents  |  About David   |  Project Videos  |  The Electronics Inside
How does handheld gaming from 1982 compare to 2004? How different are the techniques and technologies that were both capable of holding out attention for hours at a time? What counted as "cutting edge". What have we gained, and has anything been lost?
  • tei
  • computer controled
  • games console
  • nintendo
  • sewing machine
  • electronic integration
  • old electronics
  • old industrial electronics
  • tear down
  • e14presents_davidedwards
  • playstation portable
  • the electronics inside
  • a531016
    a531016 over 6 years ago in reply to humbird0
    On reassembly, I did have an issue with the analogue stick. It turns out I had put the "d pad" membrane in the wrong orientation, so it was pressing the Analogue stick and the PCB below apart. Once it was rotated, it worked fine for me! I thought the pogo pin idea was a good one, but if it doesn't last, it's no good!
    Now it's all back together, I may look into getting a SD apater for it, the 4GB memory card is only going so far!
    It's a great console, and I am enjoying the games that came with it all over again!
  • humbird0
    humbird0 over 6 years ago
    I was always very impressed with how modular and repair-friendly the PSP was... with one exception. If you ever opened the thing up, and especially if you replaced the outer case, the analog nub was likely to never work again. It had no ribbon cable or wires and relied on being physically pressed against the motherboard pins in exactly right place to function. Even after replacing mine 7 times, I could never keep it working for more than 2 minutes before it internally shifted out of place ever so slightly.
    The UMD door was never seemed to fail for me, but that was probably because I almost never opened it.
    I used an SD adapter for the memory card to store games, which also provided faster read speeds. You can still get these adapters for about $6.
    https://www.amazon.com/Funturbo-MagicGate-Playstation-Portable-Handycam/dp/B07F68FCHD
    Fun fact: It's GPU also included support for NURBS rendering, which is like using curved vectors for 3D shapes instead of polygons. Very few games used that feature though.
    Introduction of PlayStation Portable PSP
    Overall, I always felt that the PSP had a near perfect and timeless physical design. It fits perfectly into your pocket.
