The Electronics Inside
  • The Electronics Inside
Documents Hotel Door Lock Teardown -- The EIectronics Inside 31
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 8 Dec 2020 7:43 PM Date Created
  • Last Updated Last Updated: 2 Sep 2020 7:24 AM
  • Views 3589 views
  • Comments 10 comments
element14 presents
element14 Presents  |  About David   |  Project Videos  |  The Electronics Inside
Something completely different, a security application. The electronics and the mechanical design of these two door locks are so dependent on each other, but very different. Is there a better design? Which would be more secure?
  • access control
  • tei
  • door lock
  • magnetic strip cards
  • electronic lock
  • e14presents_davidedwards
  • the electronics inside
    DAB over 5 years ago in reply to a531016 +2
    Might be to keep guests and or bad guys from pouring liquid into the lock to short it out. DAB
  • baldengineer
    baldengineer over 5 years ago +1
    Being someone who, up until a few months ago, traveled quite a bit, I was very interested to see the inside of these locks! Thanks David. I was really shocked to see so much conformal coat. Environmental…
  • a531016
    a531016 over 5 years ago in reply to baldengineer +1
    I wonder if it's potentially protection from conductive dusts? When a lock is in situ and used regularly, the metal surfaces could wear if not properly lubricated creating steel and brass dusts? Maybe…
  • airbornesurfer
    airbornesurfer over 5 years ago
    If only they had those keyed-backup door locks in Jurassic Park! Apparently Mr. Hammond did, in fact, spare some expense!
  • a531016
    a531016 over 5 years ago in reply to DAB
    Good suggestion! Certainly could be?
  • a531016
    Thanks DAB!
  • a531016
    There was definately grease on them! However I suspect the grease started clear / brown and had dust in it to make it black?
    Good teardown.
    I have used many of these hotel cards and did not think anything about what was inside, so it is nice to know how some of them were put together.
  • baldengineer
    When you mentioned washing your hands at the end, is that what you thought was on them? Metallic dust, or something else?
  • baldengineer
    baldengineer over 5 years ago in reply to a531016
    That's certainly more plausible than what I was thinking.
  • a531016
    Maybe?
  • baldengineer
    I was really shocked to see so much conformal coat. Environmental protection on doors that face outside would be an obvious reason for it. But I wonder if there any other reasons for so much coating? I was thinking toward security, but that would just slow someone down--not stop them from modifying the board.
    Just a curiosity that I thought others might have ideas about.
