The Electronics Inside
  • The Electronics Inside
Documents Personal Carbon Monoxide Meter Teardown -- The EIectronics Inside 39
Join The Electronics Inside to participate - click to join for free!
  • Date Created: 18 May 2021 3:07 PM Date Created
  • Last Updated Last Updated: 13 Jan 2021 8:24 AM
  • Views 1937 views
element14 presents
element14 Presents  |  About David   |  Project Videos  |  The Electronics Inside
Industrial electronics are different. Safety electronics are different too. I don't know how chemical detection works either. Lets put all 3 together into 1 tear down and see what we get!
  • tei
  • ppe
  • personal protective equipment
  • rugged electronics
  • gas detector
  • e14presents_davidedwards
  • the electronics inside
  • mp2100
    mp2100 over 5 years ago +2
    I wear a % oxygen meter when visiting our manufacturing sites. I've disassembled them when they expire. The sensor looks similar, and has a 24 month life. I'll pull it apart to see whether it is a similar…
    DAB over 5 years ago +1
    Another great teardown. DAB
  • a531016
    a531016 over 5 years ago in reply to DAB +1
    Thanks DAB!
  • mp2100
    I wear a % oxygen meter when visiting our manufacturing sites.  I've disassembled them when they expire.  The sensor looks similar, and has a 24 month life.  I'll pull it apart to see whether it is a similar electro-chemical.  I've used a multimeter to try measuring voltage across the sensor pins, but nothing shows up.
    It has a nice 3 volt haptic motor inside to alert you in case you can't hear the piezo speaker alarm.
    The battery is a non-rechargeable lithium.  I guess they assume since the oxygen sensor wears out, you don't need a rechargeable battery.
  • a531016
    Thanks DAB!
