The Learning Circuit
  • The Learning Circuit
Documents Make a Resistor Substitution Box -- The Learning Circuit 22
  • Date Created: 11 Sep 2018 4:09 PM Date Created
  • Last Updated Last Updated: 12 Sep 2018 7:24 AM
  • Views 3347 views
  • Likes 8 likes
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
Solder along with Karen as she shows you how to review resistor codes using a substitution box.  The kit is useful for prototyping resistors. Once assembled, it can be used on an array of resistors, ranging from 10ohms to 1 mega ohm.  The kit includes the knobs to switch from ohm to kilo ohm, a PCB, a bag of resistors, and the parts for the enclosure. It also includes a manual that gives you the placement of the resistors on the PCB, its value, and its color code.  Karen is going to show you how to figure these out manually.
Product NameManufacturerQuantityPart Link
Elenco1
Buy NowBuy Now
  • stem_projects
  • tlc
  • e14presents_makerkaren
  • kilo
  • resistors
  • decade box
  • ohm
  • susbstitution box
  • prototyping circuits
  • thelearningcircuit
    beacon_dave over 8 years ago +2
    makerkaren - looks like you got one of these Velleman Kit resistor sets with the typo in the table on the back of the package. The stated tolerances for gold and silver bands appear to be reversed in the…
  • peterm1419
    peterm1419 over 5 years ago
    is this resistor sub box able to handle higher voltages?  I need it to test some resistors (dropping resistors) on old Fender amp.  One in particular.  It'd be nice not to guess.  Right now it's not letting enough DC volts thru to pre-amp.  should be higher,  I guess I could use Ohm's Law, but the box would be wonderful as there is higher input voltage than when the amp was designed (1965).
    Thanks for you're video, I enjoyed watching and learning.
    I'm talking 200 - 425 volts DC.  I hope I can use it.\
    Regards,
    Peter
  • inghernandez
    inghernandez over 7 years ago
    always is awesome.
    Regards.
    makerkaren - looks like you got one of these Velleman Kit resistor sets with the typo in the table on the back of the package. The stated tolerances for gold and silver bands appear to be reversed in the table on the back. Not sure if this set is included with the kit, but if so, one for learners to watch out for if they plan to keep the printed table for reference.
