The Learning Circuit
  • The Learning Circuit
Documents Diode Logic Light Box -- The Learning Circuit 24
  • Date Created: 1 Oct 2018 3:08 PM Date Created
  • Last Updated Last Updated: 3 Oct 2018 7:24 AM
  • Views 3015 views
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In today’s episode, we’re going to make a project using Diodes and Logic. Karen wants to build a skylight where there four LEDs, a white one for the moon and three colors (green, blue, and purple) for three different clusters of stars. It will have three switches.  If switch one is on, then the green stars and the moon will be on. Blue and purple would be off. If switch 2 is on then the blue stars and the moon will be on.  Green and purple would be off.   If switch 3 is on then the purple stars and the moon is on.  Green and Blue would be off.   To make this happen we’ll need some diodes and to draw out our circuits to see how we’ll have to wire it up, to make it work.
Product NameManufacturerQuantityBuy KitBuy Kit
2238 -  Battery Holder, PP3 (9V) x 1, Strap, Wire Leads
KEYSTONE1
Buy NowBuy Now
LED, Purple, Through Hole, T-1 3/4 (5mm), 30 mA, 3 V, 405 nmVCC 1Buy NowBuy Now
LED, Blue, Through Hole, T-1 3/4 (5mm), 20 mA, 3.2 V, 480 nmCREE1Buy NowBuy Now
LED, Green, Through Hole, 5mm, 20 mA, 3.2 V, 527 nmCREE1Buy NowBuy Now
LED, Cool White, Through Hole, T-1 3/4 (5mm), 20 mA, 3.2 V, 46.1 cdCREE1Buy NowBuy Now
Through Hole Resistor, 330 ohm, 250 mWMULTICOMP1Buy NowBuy Now
Toggle Switch, SPDT, On-Off-On, Panel, 5 AMULTICOMP1Buy NowBuy Now
Standard Recovery Diode, 1 kV, 1 A, Single, 750 mV, 30 ANTE ELECTRONICS1Buy NowBuy Now
  • logic
  • stem_projects
  • tlc
  • purple led
  • e14presents_makerkaren
  • switches
  • circuit
  • battery
  • green led
  • blue led
  • diodes
  • white led
  • thelearningcircuit
  • commanderkelly
    commanderkelly over 7 years ago in reply to makerkaren +2
    Ok I will check that out thank you. Gary.
  • commanderkelly
    commanderkelly over 7 years ago +1
    Hello Karen What was the program you used to make the circuit? BTW I love watching The Learning Circuit it helps a lot. Gary.
  • makerkaren
    makerkaren over 7 years ago in reply to commanderkelly +1
    I do all my board layout planning in Fritzing. They don't always have all the components I use, but sometimes I can find them online to download and add.
  • inghernandez
    inghernandez over 7 years ago
    I Ealy love it.
    God Job.
  • commanderkelly
    Gary.
  • makerkaren
  • commanderkelly
    Hello Karen
    Gary.
