The Learning Circuit
  • The Learning Circuit
Documents DIY Laser Light Show -- The Learning Circuit 26
  • Date Created: 16 Oct 2018 3:30 PM Date Created
  • Last Updated Last Updated: 17 Oct 2018 7:24 AM
  • Views 2858 views
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
Karen shows you how to build a laser beam projector.  It will use a laser diode and two motors with mirrors attached to their shaft so that the mirrors are are spinning. When the laser beam hits the first mirror it turns it into a circle. That circle gets reflected off of the second mirror and it's projected onto the the wall into a kind of spira trap shape. Potentiometers will allow you to adjust the speed of the motors so that we can adjust how fast the spirograph is spinning.
Product NameManufacturerQuantityBuy KitBuy Kit
Electrolytic Capacitor, Miniature, 10 µF, 25 V, 515D Series, ± 20%, Radial Leaded, 5 mm
VISHAY2
Buy NowBuy Now
Electrolytic Capacitor, 100 µF, 25 V, M Series, ± 20%, Radial Leaded, 6.3 mmPANASONIC ELECTRONIC COMPONENTS2Buy NowBuy Now
2x1 female headerMCM4Buy NowBuy Now
2x1 male headerMCM4Buy NowBuy Now
Heat Sink, Square, PCB, 31 °C/W, TO-220, 13.2 mm, 6.4 mm, 19.1 mmWAKEFIELD SOLUTIONS2Buy NowBuy Now
DC Motor, Hobby, Prototyping, 6 V, 9100 rpmAdafruit2Buy NowBuy Now
Prototype Board, 1.6 mm, 72 mm, 47 mmMULTICOMP1Buy NowBuy Now
Rotary Potentiometer, Carbon, 10 kohm, 50 mW, ± 20%, PTV09A Series, 1 Turns, LinearBOURNS2Buy NowBuy Now
6V (4) AA battery pack, Wire leadsKEYSTONE1Buy NowBuy Now
Through Hole Resistor, 47 ohm, MCMF0W4 Series, 250 mW, ± 1%, Axial Leaded, 250 VMCM1Buy NowBuy Now
Through Hole Resistor, 47 ohm, MCMF0W4 Series, 250 mW, ± 1%, Axial Leaded, 250 VTE CONNECTIVITY2Buy NowBuy Now
Toggle Switch, Subminiature, On-Off-On, SPDT, Non Illuminated, 200A Series, Through HoleE-SWITCH1Buy NowBuy Now
LM317T -1.2V to 37V, 1.5A Adjustable Positive Voltage Regulator in TO-220-3 PackageSTMICROELECTRONICS2Buy NowBuy Now
  • dc motor
  • stem_projects
  • tlc
  • e14presents_makerkaren
  • switches
  • circuit
  • rotary potentiometer
  • laser diodes
  • prototype board
  • electrolytic_capacitor
  • battery
  • heat sink
  • diodes
  • thelearningcircuit
  • toggle switch
  • makerkaren
    makerkaren over 8 years ago +4
    Here's the schematic for anyone interested.
  • mayermakes
    mayermakes over 8 years ago +1
    Awesome project!! where did you get the idea to use the lm317s? ;-)
  • mayermakes
  • mayermakes
