The Learning Circuit
  • The Learning Circuit
Documents How FETs Function -- The Learning Circuit 31
  • Date Created: 14 Nov 2018 3:47 PM Date Created
  • Last Updated Last Updated: 21 Nov 2018 8:24 AM
  • Views 6843 views
  • Likes 8 likes
  • Comments 15 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
sudo Sergeant
The Ben Heck Show
In this episode, Karen talks about the two common types of field-effect transistors, MOSFETs and JFETs. Find out the differences between them, and what it means for them to work in depletion and enhancement modes.
  • stem_projects
  • tlc
  • e14presents_makerkaren
  • thelearningcircuit
  • zlippy
    zlippy over 7 years ago +3
    This video was insanely well made. I have been struggling to wrap my head around even the basics of BJTs, and FETs for many months and this is by far the clearest explaination, I have yet seen, of a very…
  • makerkaren
    makerkaren over 7 years ago in reply to warpath78 +1
    Yeah, transistors are still a bit of magic to me. After I made the transistor episode, I found a graphic that better showed the inner makeup that really helped transistors make more sense to me. The p…
  • jc2048
    jc2048 over 7 years ago in reply to makerkaren +1
    The diagram below shows how a planar transistor (like a 2N2222 or 2N3904) is fabricated This is from a book by Robert Pease published in 1991. Note that it's not to scale - the substrate will be very much…
  • warpath78
    warpath78 over 7 years ago
    Thanks for this tutorial.  I'm having a hard time wrapping my brain around transistors but I think I'm starting to get it now.  I'm trying to figure out the Phase Light episode and this really helped.
  • makerkaren
    Yeah, transistors are still a bit of magic to me. After I made the transistor episode, I found a graphic that better showed the inner makeup that really helped transistors make more sense to me. The p-type and n-type regions in a transistor are not all the same size. It makes sense with the way the middle layer would need to be small to be overcome for electrons to flow between collector and emitter.
  • jc2048
    This is from a book by Robert Pease published in 1991. Note that it's not to scale - the substrate will be very much thicker than the other layers.
  • makerkaren
    makerkaren over 7 years ago in reply to jc2048
    Oo, that's really interesting! I'm very much a visual learned so I love diagrams that show how things are made. Thanks for sharing!
  • makerkaren
