The Learning Circuit
  • The Learning Circuit
Documents Making a FET Phase Light -- The Learning Circuit 32
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:58 PM Date Created
  • Last Updated Last Updated: 28 Nov 2018 8:24 AM
  • Views 5688 views
  • Likes 12 likes
  • Comments 19 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
Project Videos
element14 presents
Karen shows how capacitors and mosfets work together to create a project with 3 constantly shifting LEDs. Learn how to create a cool LED effect without the use of a microcontroller in this phase light project!
  • learning circuit
  • e14presents_makerkaren
  • making a fet phase light
  • jc2048
    jc2048 over 7 years ago +8
    In case it's of any interest, the circuit has its roots in this phase-shift oscillator: https://en.wikipedia.org/wiki/Phase-shift_oscillator That has three RC networks and just a single transistor to give…
  • Sean_Miller
    Sean_Miller over 7 years ago +2
    Although this is a digital solution using a MAX7219 chip, it shows a fun application of LED diffusion around 6:40 www.youtube.com/watch -Sean
  • michaelwylie
    michaelwylie over 7 years ago +2
    I can't help but notice the wool sweater and partial gloves. What do you do for static control, especially when dealing with FETs?
  • jc2048
    That has three RC networks and just a single transistor to give enough gain to make up for the losses through the passive
    components. The transistor gives 180 degrees of phase shift (an inversion) and the three RC networks contribute the other 180
    (ideally they'd each contibute 60 degrees, but for the BJT case it doesn't divide that neatly because of the way that the
    transistor loads the last stage).
    In Karen's circuit, each RC network is followed by its own gain stage. The two additional stages invert twice, leaving
    things as they were. Each gain stage can then drive an LED as its load.
    Here it is in a simulator.
    I've made the first capacitor a slightly different value (2.15uF) to the other two to encourage the simulation in getting the
    oscillation started - in a real circuit they'd never be identical (and the gate thresholds and resistors would be different
    too). The real circuit probably starts quicker than the simulation. [I've also used a voltage generator rather than a voltage
    source for the power. That just enables me to have the power applied after the simulation start time (at time = 1s).]
    First plot is all the waveforms on top of each other which shows how it gets going with one stage getting a slight edge over
    the others and then forcing the others into the sequence. The second one is with the waveforms separated and shows more
    clearly how the resulting phases drive the three LEDs.
    • Vote Up +8 Vote Down
  • makerkaren
    makerkaren over 7 years ago in reply to jc2048
    That's great additional information. Thanks, Jon!
  • makerkaren
