The Learning Circuit
  • The Learning Circuit
Documents Making a FET Phase Light -- The Learning Circuit 32
  • Author Author: kellyhensen
  • Date Created: 20 Nov 2018 7:58 PM Date Created
  • Last Updated Last Updated: 28 Nov 2018 8:24 AM
  • Views 5682 views
  • Likes 12 likes
  • Comments 19 comments
element14 Presents
Learn basic electronics, explore STEM subjects, get what you need to know to get started on electronics projects, and more.
Back to element14 Presents homepage image
Project Videos
element14 presents
Karen shows how capacitors and mosfets work together to create a project with 3 constantly shifting LEDs. Learn how to create a cool LED effect without the use of a microcontroller in this phase light project!
  • learning circuit
  • e14presents_makerkaren
  • making a fet phase light
  • jc2048
    jc2048 over 7 years ago +8
    In case it's of any interest, the circuit has its roots in this phase-shift oscillator: https://en.wikipedia.org/wiki/Phase-shift_oscillator That has three RC networks and just a single transistor to give…
  • Sean_Miller
    Sean_Miller over 7 years ago +2
    Although this is a digital solution using a MAX7219 chip, it shows a fun application of LED diffusion around 6:40 www.youtube.com/watch -Sean
  • michaelwylie
    michaelwylie over 7 years ago +2
    I can't help but notice the wool sweater and partial gloves. What do you do for static control, especially when dealing with FETs?
  • oscargrey54
    oscargrey54 over 5 years ago
    Hi everyone,
    May be it's almost two years since you guys discussed about the FET phase light, but i'm new to the FETs and i definitely need  your help. I tried to create the circuit in Tinkercad but wasn't able to achieve the Shifting effect since all LEDs were lighting together all the time. Don't know what was making  the difference.
                                               Here is my implementation of the Circuit.
    I would be grateful for all your help.
    - Oscar
  • oscargrey54
    Hi everyone,
    - Oscar
  • makerkaren
    makerkaren over 5 years ago in reply to oscargrey54
    It's been two years, but I think I know what's happening. So you created the circuit identical to the way I created it, but you're only showing a simulation, not creating the circuit IRL?
    I believe the ideal circuit, with each component manufactured exactly to spec, would, in fact, have all the lights synced. What causes them to be slightly off is the minor imperfections and slight differences between real world components.
  • oscargrey54
    oscargrey54 over 5 years ago in reply to makerkaren
    A big thanks for the reply, Karen. So, basically the Capacitors in the Simulation won't be discharging quickly or at the rate they discharge in real circuits due to which there will  be a positive voltage at the GATE of the MOSFET for most part of the time that allows the current to flow from SOURCE to DRAIN, which allow all the LEDs to glow at the Same time. Am I Correct with these points ?
    - Oscar
  • makerkaren
    The capacitors in your simulation are perfect so they would stay synced, all discharging at the same time for the exact same duration. Real capacitors are flawed so each would discharge at a slightly different rate, slightly faster or slower than each other, which is what triggers the offset. (I think)
