The Learning Circuit
  • The Learning Circuit
Documents Switches: Poles, Throws & Relays -- The Learning Circuit 44
  • Date Created: 13 Feb 2019 7:07 PM Date Created
  • Last Updated Last Updated: 20 Mar 2019 8:24 AM
  • Views 3389 views
  • Comments 10 comments
The Learning Circuit | element14 presents |  Project Videos
After doing an overview of the various types in an earlier TLC episode, Karen returns to the topic of switches to clear up the confusion involving poles and throws and to talk about how inductors factor into relays.
  • e14presents_makerkaren
  • throws
  • switches
  • karen corbeill
  • relays
  • stem projects
  • thelearningcircuit
    jw0752 over 7 years ago +3
    Hi Karen, Great presentation on switches.Some switches have an internal light which can add some extra confusion to the purpose of the connection pins. If a data sheet isn't available it is sometimes possible…
  • JoelH
    JoelH over 7 years ago +2
    Karen, Relay coils DO NOT REPEL the actuator, they either Attract, or Release the actuator. a Spring returns the actuator the "Normal" position (as in Normally Open/Closed as opposed to the abnormal or…
    DAB over 7 years ago +2
    Very good episode Karen. In the old days, we had to hand clean relay contacts when they became covered in carbon due to the sparking of voltage and current in heavy use. The newer relays are much less…
  • #datsun240z
    #datsun240z over 6 years ago
    Hello to all and anyone that can please help =)
    My name is Frank and I was wondering if anyone would be kind and take some of your time to help me identify and find a replacement switch used in a japanese automobile built in the 70's.  Replacement and recondition parts for these vehicles are becoming unaffordable to the public and some sellers on Ebay are asking up to $600.00 for the parts.
    All information on how the switch works can be found on this link under "how the hazard switch works" and a picture can also be found under figure #1 about the terminals it uses.
    http://woodworkerb.com/home/datsun-240z-rebuild/datsun-240z-multifunction-switches/
    My goal is to find and buy a switch online  that does the same function and can be wired in the same way to exchange the original hazard switch out for the more afforadable switch,  if possible.
    I also plan to create a very simple video on YouTube and post the information on an existing car blog.
    Thank you all in advance for your time and effort.
    God bless
  • #datsun240z
    God bless
  • makerkaren
    makerkaren over 6 years ago in reply to #datsun240z
    From what I can tell that seems like a very specific, and proprietary switch. It looks like pins 4&5, and 6&7 are tied to each other when the switch is off, and Pins 1,2,3, 8, 9 are all tied together when it's on. You're not going to find a switch that does exactly that.
    You could potentially create a new one from scratch, but I don't think you're going to find a switch exactly like the original that you can straight swap in.
