The Learning Circuit
  • The Learning Circuit
Documents Soldering A Voice Changer Kit -- The Learning Circuit 47
  • Date Created: 2 Mar 2019 7:02 PM Date Created
  • Last Updated Last Updated: 1 May 2019 7:24 AM
  • Views 4235 views
The Learning Circuit | element14 presents  | VCP Biography: Karen |  Project Videos
The last episode we learned all about sound components, those that make them and those that interpret them. In this episode, Karen assembles as Velleman MK171 Voice Changer kit. She walks you through the instructions, reviewing symbols, components, and concepts learned in previous episodes. This circuit has uses 2 IC chips, LM386N op-amp, and an HT8950, voice modulator chip. When sound is interpreted by the microphone, the signal goes through these ICs, is processed, and changed to modulate the user’s voice. Using the tac switch buttons on the PCB, the voice can be changed, adding vibrato, adjusting the pitch up and down, or made to sound like a robot. The circuit also includes variable resistors that allow for changing the microphone sensitivity and the speaker’s output volume. Batteries and speaker not included.
Bill of Materials
Bill of Materials
Digital Voice Recorder Single Message Kit Vellemam 1 Buy Now
Speaker, Micro, Dynamic, 0.3 W, 8 ohm, 92 dB, 560 Hz to 7 kHz Kignstate 1 Buy Now
Speaker, Mini, Dynamic, 2 W, 8 ohm, 200 Hz to 20 kHz Multicomp Pro 1 Buy Now
Battery, 9 V, PP3, Alkaline, 565 mAh, Snap Contact Multicomp Pro 1 Buy Now
image 47 Electronic Voice Changer Script.pdf
  • element14 presesents
  • 9 v battery
  • e14presents_makerkaren
  • voice changer kit
  • the learning circuit
  • thelearningcircuit
  • speaker
    DAB over 7 years ago
    Very good episode.
    You did a good job assembling the circuit, taking the proper precautions with the polarized components and following directions.
    Well done.
    Very good episode.
    Well done.
