The Learning Circuit
  • The Learning Circuit
Documents Electronic Dice Kit -- The Learning Circuit 49
  • Date Created: 25 Mar 2019 6:51 PM Date Created
  • Last Updated Last Updated: 12 Jun 2019 7:24 AM
  • Views 3911 views
  • Comments 7 comments
Electronic Dice Kit
The Learning Circuit | element14 presents |  Project Videos | VCP Biography: Karen
In the previous episode, Karen did an overview of integrated circuits or ICs. This week, Karen chose an electronics kit that contains two ICs, a phase locked loop, and a ripple binary counter. A phase locked loop takes one external input and one internal input, comparing the frequencies of their signal and turns that difference into a voltage that goes back to adjust the internal signal. This process continues until both external and internal signals are equal. This process generates an output signal that slowly changes then stabilizes. In today’s kit, an electronic dice kit, that signal from the phase locked loop IC is used as the clock input signal of the second IC, the binary counter.
The binary counter IC is a 7-stage ripple counter, with each stage generating a binary digit.
Once you understand how to count in binary, you can see that each digit is created as a square wave signal. In the end, the ripple counter IC outputs a signal that randomly flashes the 7 LEDs ending in a die roll of a typically 6-sided die.
Bill of Material:
Part
Hobby Project Kit, Electronic Dice, Single, Simulated Random Dice Roll
Velleman1Buy NowBuy Now
9V BatteryEnergizer1Buy NowBuy Now
  • element14 presesents
  • phase detector
  • loop filter
  • binary
  • e14presents_makerkaren
  • 6-sided
  • d6
  • vco
  • the learning circuit
  • integrated circuits
  • ics
  • ripple counter
  • phase locked loop
  • dice
  • binary counter
  • thelearningcircuit
  • voltage controlled oscillator
  • jc2048
    jc2048 over 7 years ago +4
    I'm sorry to have to say this, after all your hard work researching PLLs and explaining them to us, but from the circuit diagram it looks like the designer just used the VCO [voltage-controlled oscillator…
    DAB over 7 years ago in reply to makerkaren +1
    HI Karen, What I find most useful are the voltage and current values plus the timing for the gate operations. Next would be logic tables followed by clock pulse edges. The voltage and current provides…
    shabaz over 7 years ago +1
    It's fun trying to think of ways to implement dice : ) Here's my attempt (as a teenager), it was published in some magazine at a time of less scrutiny. IC1 is 40106, and IC2 is 4029. The LEDs are in this…
  • jc2048
    I'm sorry to have to say this, after all your hard work researching PLLs and explaining them to us, but from the circuit diagram it looks like the designer just used the VCO [voltage-controlled oscillator] part of the chip; it's not functioning as a loop. The VCO frequency is simply set by the voltage on C2. When you release the switch, the capacitor discharges and the frequency falls until it no longer oscillates and the counter then stops counting.
    An interesting question, for someone learning electronics, would be to ask them which numbers they would bet on coming up the most (if you puzzle out how the diodes and the transistor decode from the 3-bit counter [= 8 states] you'll find that two of the numbers come up twice, though they're displayed differently each time).
  • makerkaren
    makerkaren over 7 years ago in reply to jc2048
    Hahaha. That's totally fine! I was so busy making sure I understand how the chips worked that I didn't even think to thoroughly investigate how they were connected to the rest of the circuit. Thanks for pointing that out actually. I'm always happy to see others explain anything I missed or left out or even made an error on. It's all about learning!
  • makerkaren
