The Learning Circuit
  • The Learning Circuit
Documents Intro to Integrated Circuits -- The Learning Circuit 48
  • Author Author: rjena
  • Date Created: 21 May 2019 2:16 PM Date Created
  • Last Updated Last Updated: 22 May 2019 7:24 AM
  • Views 3590 views
  • Likes 9 likes
  • Comments 9 comments
The Learning Circuit | element14 presents  | VCP Biography: Karen |  Project Videos
Any circuits that have more than the most basic of functions requires a little black chip known as an integrated circuit. Integrated circuits, or ICs, fall into 3 categories, analog, digital, or mixed signal. Analog signals can vary in the entire range between the minimum and maximum signals. In the case of this graphic, any voltages between 0V and 5V. Digital signals are typically on or off, high or low, represented by a 1 or 0.  Analog ICs are most commonly used for regulation or amplification. Since sound, voice, and music signals are typically analog, they frequently make use of analog ICs. Digital signals, being much simpler as only having two states, allow for the sending and storing of data much more easily and efficiently. Some ICs have components that allow the conversion of analog and digital signals from one to another. These are known as mixed signal ICs. Follow along to learn about voltage regulators, op-amps, logic gates, 555 timers, microcontrollers, ROM, RAM, and more. Have a question about an IC type Karen didn’t cover? Post your questions in the comments below!
  • element14 presesents
  • e14presents_makerkaren
  • the learning circuit
  • integrated circuits
  • thelearningcircuit
  • jc2048
    jc2048 over 7 years ago +6
    Old EPROMs had a quartz window (so that they could be erased with UV light) and that gave a fascinating glimpse of the chip inside and the bond wires. The transistors that made up the memory were arranged…
  • baldengineer
    baldengineer over 7 years ago +5
    Excellent job consolidating a massive amount of information on such a broad topic. (Are all ICs are the same, right?) At first, I thought, "I'll just watch for a minute or two." Without realizing it, I…
  • kid001
    kid001 over 5 years ago +3
    This is me in tears of joy, never seen such a wonderful platform to learn a lot of electronics and get a lot of information like this thank you so much you explain topics well, soon will be ordering some…
  • neilk
    neilk over 5 years ago
    Great video, Karen!
    Keep up the good work
    Neil
  • neilk
    Great video, Karen!
    Neil
