The Learning Circuit
  • The Learning Circuit
Documents How Op Amps Work -- The Learning Circuit 68
  • Date Created: 19 Feb 2020 6:39 PM Date Created
  • Last Updated Last Updated: 4 Dec 2019 8:24 AM
  • Views 6547 views
  • Likes 8 likes
  • Comments 5 comments
How Op Amps Work
The Learning Circuit | element14 presents |  Project Videos
In this video, Karen presents and introduction of op amps how various ways they can be used in circuits. At a basic level, op amps are quite simple. They compare the voltages at their two outputs and use the difference in voltages to determine how the signal is amplified. The differential voltage at the inputs often needs to only be a few microvolts to generate an amplified signals. To be able to finely control the gain, a feedback loop must be created between the op amp’s output and one of the inputs. This loop usually contains a resistor and/or capacitor to have finer control of the gain. Check out this Intro to Op Amps episode to learn more about how op amp works and a variety of its applications.
  • inverting
  • monostable
  • opampsch
  • differentiator
  • subtractor
  • gain
  • e14presents_karencorbeill
  • e14presents_makerkaren
  • summing
  • astable
  • negative feedback
  • non-inverting
  • feedback
  • adder
  • multivibrator
  • differential
  • live2divedeep
    live2divedeep over 6 years ago
    Tig welder repair. After i confirmed proper waveform at output in Ac and Dc... But no arc/start.....also no volt/amp isplay(8hexdecimal) Ive been investigsting the control board and about to test ic chips(op amps) for output signals...... Should check feeback circuit first?
    Thanks in advance!
  • live2divedeep
    Thanks in advance!
