The Learning Circuit
  • The Learning Circuit
Documents 555 Timers - How Bistable Mode Works -- The Learning Circuit 70
  • Date Created: 14 Apr 2020 7:08 PM Date Created
  • Last Updated Last Updated: 8 Jan 2020 8:24 AM
  • Views 5856 views
  • Likes 8 likes
  • Comments 13 comments
The Learning Circuit | element14 presents |  Project Videos
Karen has been digging into 555 timers for a bit now. In a previous video, she did an overview of the 3 different modes in which a 555 timer can be used. In this video, Karen goes into further detail about one of those modes: Bistable. In bistable mode, signals at two inputs are used to manually set the output of the 555 timer high or low. For example, one button could trigger the output to turn a light on, while a second button could reset the output to turn the light off. This video goes over what is happening in the 555 timer internally to make this type of circuit work. Karen also presents a practical example on a breadboard to show using a 555 timer in bistable mode.
Bill of Material:
Product Name Manufacturer Quantity Buy KitBuy Kit
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mm Multicomp 1 Buy NowBuy Now
LM555CN - Timer, Oscillator & Pulse Generator IC, TTL Compatible, Astable, Monostable, 4.5 V to 16 V, DIP-8 On Semiconductor 1 Buy NowBuy Now
Ceramic Disc Capacitor, 0.01 µF, 100 V, ± 20%, 5 mm Vishay 1 Buy NowBuy Now
140 Pc. Jumper Wire Kit, 22 AWG, Solid, Assorted Lengths and Colors Twin Industries 1 Buy NowBuy Now
Through Hole Resistor, 220 ohm, 400 mW, ± 1% Vishay 1 Buy NowBuy Now
Through Hole Resistor, 1 kohm, 500 mW, ± 1% TT ELECTRONICS / WELWYN 2 Buy NowBuy Now
Red LED, Through Hole, 5mm, 20 mA, 2.1 V LED TECHNOLOGY 1 Buy NowBuy Now
Tactile Switch, 12mm, Yellow, Top Actuated, Through Hole, Round Button, 24 VDC, 50mA Omron 1 Buy NowBuy Now
Tactile Switch, 12mm, Red, 12 VDC, 50mA Multicomp 1 Buy NowBuy Now
Additional Parts:
Product Name
Desktop Power Supply
  • e14presents_karencorbeill
  • bistable
  • e14presents_makerkaren
  • the learning circuit 70: 555 timers - how bistable mode
  • 555 timer
  • 555 timers
  • 555
    jw0752 over 6 years ago in reply to fmilburn +5
    Hi Frank, I couldn't find my schematic of the two different circuits until just now. Here is what they look like. John
    jw0752 over 6 years ago in reply to fmilburn +2
    Hi Frank, I don't know if they never got properly inserted or what. I can't edit the original post so I will insert the pictures here. The pictures add a little color but are probably irrelevant as they…
  • makerkaren
    makerkaren over 6 years ago in reply to aswinvenu +2
    Yeah, since I've made so many videos about 555 timers, I was trying to not repeat myself too much. Looking back there are a few times I should have kept in details such as this. Those editing choices get…
    Hi Karen,
    As usual your informative posts makes me want to look a little deeper into the subject presented. Thank You for the great job you are doing. When I went looking into bi-stable configurations of the 555 I found (2) main designs.
    Fullscreen contentimage_191434.html Download
    <html><head><title>Jive SBS</title></head>
    <body><font face="arial,helvetica,sans-serif">
    <b>Error</b><br><font size="-1">
    An general error occurred while processing your request.
    </font></font></body></html>
    If you had a reason I was wondering why you chose one design over the other. I also learned that the #4 pin has an internal resistor that pulls it high normally so connecting it to Vcc is an option in your design. When I set the two designs up side by side on a bread board I could find no functional difference between them, just two different ways to do the same thing. This is what makes electronics so fascinating. there is creativity and art involved as well as technical aspects. Here is a picture of the two side by side designs that I bread boarded. You will note that I put in a Red LED for an indication of a High Output from Pin 3 and a Green LED for a Low output of Pin 3.
    Fullscreen contentimage_191435.html Download
    Fullscreen contentimage_191436.html Download
    Thanks again for inspiring an interesting afternoon
  • fmilburn
    fmilburn over 6 years ago in reply to jw0752
    Hi John,
    Another nice post by Karen but the photos you posted are not showing in my iPad browser
    Hi Frank,
    The pictures add a little color but are probably irrelevant as they don't really show much.
  • fmilburn
    Thanks John,
    I wasn't aware there were two methods and just wanted to make sure I am not missing something else :-).  They do show how neat your work is, even on a breadboard.
  • fmilburn
    Thanks John,
    Hi Frank,
    • Vote Up +5 Vote Down
