The Learning Circuit
  • The Learning Circuit
Documents 555 Timers - How a One Shot Timer Works -- The Learning Circuit 71
  • Date Created: 28 Apr 2020 5:55 PM Date Created
  • Last Updated Last Updated: 29 Jan 2020 8:24 AM
  • Views 3880 views
The Learning Circuit | element14 presents |  Project Videos
Karen has been digging into 555 timers for a bit now. In a previous video, she did an overview of the 3 different modes in which a 555 timer can be used. In this video, Karen goes into further detail about one of those modes: Monostable. Monostable mode is also known as a “one-shot” timer. In this mode, a single input signal of the 555 timer triggers it’s output to go high. The design of the rest of the external circuit will then cause the output to automatically reset back to low. Karen explains what’s happening inside the 555 to make this work, as well as showing a practical example of how to create this circuit on a breadboard.
Bill of Material:
Product Name Manufacturer Quantity Buy KitBuy Kit
Breadboard, MCM 60 rows, ABS, 8.5mm, 165mm x 56mm Multicomp 1 Buy NowBuy Now
LM555CN - Timer, Oscillator & Pulse Generator IC, TTL Compatible, Astable, Monostable, 4.5 V to 16 V, DIP-8 On Semiconductor 1 Buy NowBuy Now
Ceramic Disc Capacitor, 0.01 µF, 100 V, ± 20%, 5 mm Vishay 1 Buy NowBuy Now
140 Pc. Jumper Wire Kit, 22 AWG, Solid, Assorted Lengths and Colors Twin Industries 1 Buy NowBuy Now
Through Hole Resistor, 220 ohm, 400 mW, ± 1% Vishay 1 Buy NowBuy Now
Through Hole Resistor, 1 kohm, 500 mW, ± 1% TT ELECTRONICS / WELWYN 2 Buy NowBuy Now
Red LED, Through Hole, 5mm, 20 mA, 2.1 V LED TECHNOLOGY 1 Buy NowBuy Now
Tactile Switch, 12mm, Yellow, Top Actuated, Through Hole, Round Button, 24 VDC, 50mA Omron 1 Buy NowBuy Now
Tactile Switch, 12mm, Red, 12 VDC, 50mA Multicomp 1 Buy NowBuy Now
Additional Parts:
Product Name
Desktop Power Supply
  • one shot timer
  • monostable
  • tlc
  • e14presents_makerkaren
  • through hole resistor
  • desktop power supply
  • 555 timer
  • 555 timers
  • 555
  • celcius1
    celcius1 over 6 years ago +1
    One place where you’ll find this circuit is on a VIC-20 it uses a 555 to hold the reset line high during power on, before going low.
  • celcius1
  • celcius1
