The Learning Circuit
  • The Learning Circuit
Documents How Shift Registers Work -- The Learning Circuit 75
  • Date Created: 14 Jul 2020 4:34 PM Date Created
  • Last Updated Last Updated: 15 Apr 2020 7:24 AM
  • Views 4840 views
The Learning Circuit | element14 presents |  Project Videos
Shift registers are devices that are quite popular when using microcontrollers as they can be used to expand the number of inputs or outputs available. In this lesson, Karen explains how serial and parallel data are used and shifted through these devices. Learn how shift registers are made of logic devices as she breaks down the logic diagrams and shows how to read the timing diagrams to understand exactly how these ICs work.
  • clock
  • series
  • flip flop
  • piso
  • timing diagram
  • sipo
  • e14presents_makerkaren
  • logic diagram
  • siso
  • latch
  • serial
  • pipo
  • shift_register
  • parallel
    DAB over 6 years ago +4
    Hi Karen, Very good episode. One way to look at the difference between a flip-flop and a latch is the following. A flipflop changes state with each event, ie a clock. A latch holds a state until enabled…
    jw0752 over 6 years ago +1
    Hi Karen, Nice presentation as usual. John
  • makerkaren
    makerkaren over 6 years ago in reply to DAB +1
    That makes a lot of sense! Thanks!
    Hi Karen,
    Very good episode.
         A latch holds a state until enabled to receive new data.
    You see this effect in the one example where you have serial data coming in and then a separate latch for the output. Without the latch, the intermediate states of the shift register would be available on the output. In some circuits, that effect could lead to the wrong data triggering the next circuit stage. With the latch, you allow the serial data to accumulate until it is all available before you "latch" it into the output. This logic sequence allows you to pass only valid data onto the next circuit step.
    The circuit you build determines if you can use a flipflop or a latch. An asynchronous circuit will usually use flipflops, again depending upon what you are doing.
    A synchronous circuit will use latches to ensure that all of the stored data states are valid at the same time before you enable the next step to proceed.
    The really cool thing with shift registers are that they enable you to do binary divide and multiplication of the data. Each shift step moves the data left or right performing a multiply by 2 if you go left or a division by 2 if you move right.
    You can have lots of fun with shift registers.
    Hi Karen,
    Very good episode.
  • makerkaren
