element14 presents
element14 presents
Documents Build Inside The Box - Brainstorming Call!
  • Author Author: kellyhensen
  • Date Created: 28 Apr 2021 2:07 PM Date Created
  • Last Updated Last Updated: 11 Jun 2021 4:30 PM
  • Views 3376 views
  • Likes 8 likes
  • Comments 14 comments
element14 presents
About the Challenge | Contestants | The Prizes | element14 Vault Giveaway | The Box | Terms & Conditions
Click on the banner below to register for the upcoming live stream to see which of your favorite vcp project has won:
Our Build Inside The Box challenge was designed to celebrate our 500th episode of element14 presents.  We chose three of our video hosts to go head to head in the competition to build the best the project that must use ALL of the products in The Box.
The challengers (James, Katie and Clem) met virtually to discuss the parts and their initial ideas on building a working project that uses ALL of the parts in The Box.
Unsupported video URL format.
If you're looking for the product links, you need to see What's in The Box !
  • Which part is the one that the project will be built around?
  • Which part is the hardest to integrate into a working project?
  • How does that temperature sensor actually work?
  • What coding language best fits the desired functionality?
These and other exciting questions are discussed in this video.
Join the conversation by posting your ideas and commenting below!
You still have time to participate in the Build Inside The Box Challenge - your project blogs for the member contest are due Tuesday, 7th May 2021 5pm CDT.
  • build inside the box
  • bitb
  • mayermakes
    mayermakes over 5 years ago +3
    it is so hard to get all the components into a single project. I just hope to make a project practical enough to justify not using all the parts to the full extent. I'm so courious about what all the people…
  • kellyhensen
    kellyhensen over 5 years ago +3
    Sharing some links to brainstorming other members are doing as they "Build Inside the Box" What's in the box! Don't look in the box! easyejl Build Inside the Box - James O'G - Build log -Update Sunday…
  • aspork42
    aspork42 over 5 years ago +2
    Awesome video - I have had the same 'roller coaster' experience with all the components. Some I've got 100% locked in, and others it took a lot of pondering to decide and figure out. James - you noted…
  • easyejl
    easyejl over 5 years ago
    I had also considered the theramin route image but my wife suckered me into running with her idea instead image
    Figure you mount one of the TOFs pointing horizontally, put the other on an arm contraption so it can rotate, but always point vertically. it could have an encoder wheel to use the phototransistor. the horizontal one controls tone + position of the vertical one, the vertical one controls volume. Still no idea how I would have worked the thermo reader into that though.
  • baldengineer
    baldengineer over 5 years ago in reply to easyejl
    One idea I briefly had for the temperature sensor was a really slow-to-respond touch sensitive button. In my testing, I found that touching the sensor with my finger would raise it 2-3 C within a second. And it seemed to be a relatively steady rise. (of course, I wasn't doing anything with the data, so what looked linear to me may not have been!)
  • baldengineer
