WorkBench Wednesdays
  • WorkBench Wednesdays
Blog Are you still using 7400-Series Logic, if so, where?
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: baldengineer
  • Date Created: 9 Dec 2020 7:50 PM Date Created
  • Views 9489 views
  • Likes 11 likes
  • Comments 37 comments
  • 7400 logic chips
baldengineer
baldengineer
9 Dec 2020
Over the past several months, I have been learning about and repairing 8-bit computer and video game systems. So far, I have worked on the VIC-20, C64, ZX-81, Apple II, and have been learning about the TI 99/A.
It always amazes how much of these early computer systems were built almost entirely with standard 7400-series (LS and HC) chips.
Occasionally, I need to replace a 7400-series chip. (I always hope it is one of those and not one of the ASICs!) While looking for modern replacements, I have noticed the trend that they are becoming more scarce. The LS-series is almost entirely gone--and with good reason. While HC and HCT continue to be somewhat available, they are usually only available in surface-mount packages.
That leads me to the question: Who is still using the venerable 7400-series logic chips today?
To me, there are three groups that might be using them:
  1. Learning. Students and hobbyist learning about digital logic
  2. New Design. Hardware that needs glue-logic. Are these using multi-gate chips or the single-gate variants?
  3. Repair. Older electronics in need of replacements. Here is where I mostly sit.
Do you fit into one of those categories? If not, where do you land?
And THEN, which chips are the must-have on-hand?
Obviously, the answer depends on how you might be using them. But, I'm curious to know how you use 7400-series chips and which ones would you keep in stock?
  • michaelkellett
    michaelkellett over 5 years ago +13
    The high spot of my 74xxx design works was about 1987 when I designed this beastie. Subsequent designs used FPGAs or micro-controllers. I was lucky enough to find one on Ebay recently, not quite working…
    shabaz over 5 years ago +8
    Here an electronics chain called Maplin was selling 74-series TTL right until 2018, when it closed for good! I guess people were still buying them, perhaps to repair old equipment. I think this is the…
  • ralphjy
    ralphjy over 5 years ago +7
    I just used a couple of 4000 series logic chips in the Pong game that I rebuilt. And I have an assortment of 74 and 74LS (even some 54 mil grade parts) from the late 70s and early 80s when I did a lot…
    dougw over 5 years ago in reply to ntewinkel
    Yes 4000 series could run from about 3V to about 18V.
  • koudelad
    koudelad over 5 years ago
    I have never used nor seen these logic chips in anything I disassembled that was designed in last 10 years or more. I personally used micro-controllers, but as other say, high speed designs need CPLD or an FPGA.
    One great alternative is a PSoC or other MCUs with some kind of configurable logic cells.
  • koudelad
    koudelad over 5 years ago in reply to baldengineer
    I think 74C series is the equivalent of 4000-series, with a broad power supply voltage 3-15 V. However, HC is high speed and typically operates at 2 - 5 V.
  • baldengineer
    baldengineer over 5 years ago in reply to dougw
    Are 7400HC the same as 4000-series? Or are there different gates in the 4000-series?
  • baldengineer
    baldengineer over 5 years ago in reply to genebren
    genebren  wrote:
    The 74HC4006D was my go to part for routing/switching control voltages in some of these designs.
    Is the 74HC4066 the same as a CD4066B?
