WorkBench Wednesdays
  • WorkBench Wednesdays
Documents Win a Tenma Power Supply
Join WorkBench Wednesdays to participate - click to join for free!
  • Author Author: kellyhensen
  • Date Created: 19 Sep 2019 2:23 PM Date Created
  • Last Updated Last Updated: 19 Nov 2019 6:47 PM
  • Views 8071 views
  • Likes 15 likes
  • Comments 128 comments
Congratulations to our winners!
Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through.
The winner of the Tenma Supply is Andrew J!
His submission literally made James laugh out loud: turning the supply into a mouse to scare a cat.
Congrats on your new supply!
But that's not all! We're going to find some element14 Community swag for the following honorable mentions:
neuromodulator
liamsenior
dougw
javagoza
This giveaway is closed.
Now that you know the basics of how to use a power supply, wouldn't it be great to have one to use on your very own bench?  Well, you are so lucky because James has one to give away!
Unsupported video URL format.
James is always looking for novel ideas for how to use the equipment on his work bench. . . so in this contest, he's asking for ideas on the most unique use for a power supply that maybe isn't just using it as a power supply.  (I don't think he means gutting it and using it for a potted plant.)
Add your suggestion in the comments below (no later than Friday, November 1) and you're entered with a chance to win.
James will select the winner and announce her/him on this page no later than November 14, 2019.
Learn More about the Tenma Power SupplyLearn More about the Tenma Power Supply
Full Terms and Conditions
  • giveaways
  • ww_giveaway
    dougw over 6 years ago +10
    I would like to set this power supply up to be able to rapidly test USB cable performance. I have a large collection of USB cables that is still growing. It seems every device comes with yet another USB…
  • baldengineer
    baldengineer over 6 years ago +9
    Wow! You guys came up with some really creative ideas! There were over 100 individual ideas submitted and they were a blast to read through. The winner of the Tenma Supply is Andrew J ! His submission…
    Jan Cumps over 6 years ago +8
    That is a very good PSU! also: I encourage baldengineer to give away *all* the equipment that we can see in the video
    jw0752 over 6 years ago in reply to cyborg73703
    Hi Kyle,
    Wouldn't any arc capable of blasting off corrosion also produce enough heat to melt the metal of the contact? Then you would have a corroded and arc pitted contact which may not be very dependable. Surprisingly most switches can be taken apart and the contacts cleaned with a typewriter eraser if replacing them with a new switch isn't an option.
  • 14rhb
    14rhb over 6 years ago in reply to cyborg73703
    Have you ever noticed this technique to have a negative effect, whereby the contact dirt carbonises further causing additional arcing and burning ?
  • cyborg73703
    cyborg73703 over 6 years ago in reply to dougw
    It takes a few sacrifical switches to figure out at which point of your max current causes damage when the switch contacts arc.
    But once you figure that out, set the voltage to the voltage the system runs at that the micro switch is in, and current you've come up with before it causes more harm than good.
    Usually micro switches see very little current as they're running relays commonly, so with the current supplied by the power supply this usually cleans corrosion, causing high resistance, off the contacts.
    Can be very valuable for expensive or obsolete switches.
    dougw over 6 years ago in reply to cyborg73703
    cyborg73703 Sounds interesting - can you describe your method?
  • cyborg73703
    One of the most interesting ways I've used a benchtop PSU is to clean contacts on micro switches that measure out of spec.
    Being able to control current is key.
  • crisald
    crisald over 6 years ago
    Hello,
    I will use this power supply to power up a free energy generator.
  • embai
    embai over 6 years ago
    You will laugh but I will use that voltage knob as the volume meter of music synthesizer or to destroy electronic components to understand better when a capacitor will blow up and why. I'm really curios so another experiments may occur i.e. Water electrolysis, making a strong magnetic coil making a dehumidifier with peltier!
  • mitrynicolae
    mitrynicolae over 6 years ago
    Hello,
    A good Power supply can be used in a repair Shop. With it you can find shorts on a board, Power up certain parts of a board or check if some subcomponents work as they should.
    I suppose that the above comment said clearly that I wish the Power supply.
    Bye!
  • sprionk
    sprionk over 6 years ago in reply to minerwelder
    Oh yes! That's always a helpful little thing to do isn't it?
  • sprionk
    Oh my poor, poor current PSU (one of those dodgy no-brand ones). It currently has some lovely "nonstandard" roles it plays:
    • I've tapped off some dedicated wiring and a switch, and connected it to an LED lightbulb to light my workstation (arandomengineer, your joke is my reality!)
    • Shorting it with some Nichrome wire makes for a great hot-wire cutter (with temperature 'control', no less!) for making polystyrene boxes for thermally insulated projects
    • Snip the end off a USB to USB-C cable and now I can charge my phone in the lab too! (It's not fried the phone yet, but if you can't trust your power supply, what can you trust?!)
    • Charging lithium based batteries before using them in projects.... and also my car battery when I couldn't find someone to jump start my car (twice)
    I've only needed to replace internal components in my PSU once so far and considering the uses it has besides powering my projects, I'm surprised it's only died once! Having a supply that's a bit more.... actually well made... would be a great change
