7-Segment Display
  • 7-Segment Display
7-Segment Display
Blog Simulate 7-segment circuits in your web browser!
  • Author Author: scottiebabe
  • Date Created: 31 May 2022 3:00 PM Date Created
  • Views 54916 views
  • Likes 17 likes
  • Comments 10 comments
scottiebabe
scottiebabe
31 May 2022
I recently came across the online circuit simulator Wokwi. So, I don't really know what to say just yet. But, I am certainly impressed to say the least. I copied my RPI Pico 7-segment design into the simulator and it ran just fine.
Pretty incredible!
I believe anyone can see the project, if you want to try the simulator here is the project link: https://wokwi.com/projects/331838877263200851
I am even more impressed how far down the rabbit hole the simulator goes. I also tried one of my more complicated buswrite function which addresses the gpio registers in memory and that worked fine too!
SIO_BASE = 0xd0000000
def BusWrite( b0, bn, v ):
    n = bn-b0+1
    bitmask = (0xFFFFFFFF >> (32-n)) << b0
    scratch = mem32[SIO_BASE+0x10] # read GPIO output reg
    scratch &= ~bitmask
    scratch |= v << b0
    mem32[SIO_BASE+0x10] =  scratch
I tried another sample project with an arduino and an MPU650:
I added the logic analyzer block myself to monitor the I2C bus. After stopping the simulation, I got a value change dump file name "wokwi-logic.vcd"
I imported the VCD file into sigrok and added an I2C, decoder:
You can even adjust sensor values in real time!
I found this sample project at the bottom of the mpu modules help guide located at: https://docs.wokwi.com/parts/wokwi-mpu6050
  • ralphjy
    ralphjy over 4 years ago
    Very interesting.  Thanks for the link.  I'm actually away from hardware for a while and it will be fun to give the simulator a try.
    I was somewhat surprised that it also has WiFi capability and even provides a PCAP file so that you can capture transactions using WireShark!
  • scottiebabe
    scottiebabe over 4 years ago in reply to ralphjy
    O my goodness, it even simulates a guest WIFI network for simulating an IOT projects. Pretty fancy! Nice discovery :)
  • scottiebabe
