Acoustics
  • Acoustics
Acoustics
Blog Nexgen: FAA Nav Aid Station Morse Code - Software
Join Acoustics to participate - click to join for free!
  • Author Author: phoenixcomm
  • Date Created: 5 Apr 2020 10:23 PM Date Created
  • Views 1125 views
  • c
  • arduino mega 2560
  • sender
  • morse code
  • diy
  • p14acousticsch
  • can bus listener
  • acousticsch
  • nexgen flight simulator
phoenixcomm
phoenixcomm
5 Apr 2020
Ok, I have not been diligent in producing some software. Most of the algorithms that I have seen to do this job are rather slow. I have defined a MAX_LETTERS as a constant of 10 which will give me generous room for my ID Code. Since I like to modular my code I will need to write a function void sendTone( char 'letter' );image
BTW this device (Arduino) is a listener con the CAN bus.
MorseCode.hMorseCode.c
// morseCode d==dot D==Dash
//morseCode[value][string]
char morseCode[26][MAX_LETTERS] = {
"dD",   "Dddd", "DdDd", "Ddd,
"d",    "ddDd", "DDd",  "dddd",
"dd",   "dDDD", "DdD",  "dDdd",
"DD",   "Dd",   "DDD",  "dDDd",
"DDdD", "dDd",  "ddd",  "D",
"ddD",  "dddD", "dDD",  "DddD",
"DdDD", "DDdd"};
//units
const int TIME_UNIT = 250ms
const int DOT = TIME_UNIT;
const int DASH = 3 * TIME_UNIT;
const int C_SPACE = 2 * TIME_UNIT;
const int W_SPACE = 5 * TIME_UNIT;
const int LETTER_SPACE =
const int MAX_LETTERS = 10;
// Commands:
const int sendDot = 1;
const int sendDash = 2;
const int sendC_space = 3;
const int sendL_space = 4;
const int sendW_space = 5;
// pre-defines
getWord( char *name );
#include <stdio.h>
#include <stdlib.h>
#include <morseCode.h>
int main() {
getWord( char *name ){
    char letter;
    for( int count = 0; count <= MAX_LETTERS; count++)
        if( letter = name[count] != '\n') {
            int offset = 0x40 - letter;
            for(int v = 0; code = morseCode[offset][v] != '\n'; v++) {
                   If ( code  == 'D' || code == 'd' )  {
                          sendMorse(  L, code ); }
                   elseif (code == {
                           sendMorse( S, code ); }
return EXIT_SUCCESS;
Notes: the char array morseCode is an array of strings which are automatically terminated with a '\n'
void sendTone( char tone ) {
//  To be done later;
// please ignore the sendTone and sendSpace They have been replaced with a new function
int sendMorse( int command char*  Sound ) {
       switch ( command } {
            case sendDot: {
                   // generate Sound
                   break; }
            case sendDash: {
                   // generate Dot
                   break; }
            case sendC_space: {
                    // generate Sound
                   break; }
            case sendL_Sound: {
                   // generate Sound
                  break; }
            case sendW_space: {
                    // generate Sound
                   break; }
            defualt; { }}}
void sendSpace( int space ) {
// to be done later;
  • phoenixcomm
    phoenixcomm over 6 years ago in reply to cstanton +1
    cstanton All Navaid stations transmit their ID in Morse Code. Its kind of mandatory in a Nav System.
  • phoenixcomm
  • cstanton
    cstanton over 6 years ago
    What part does this play in the overall project?
