Animatronics
  • Animatronics
Animatronics
Blog Hey Moogle - an animatronic moose assistant
Join Animatronics to participate - click to join for free!
  • Author Author: easyejl
  • Date Created: 13 Nov 2019 8:31 PM Date Created
  • Views 7817 views
  • Likes 9 likes
  • Comments 52 comments
  • animatronicsch
easyejl
easyejl
13 Nov 2019
My wife and I went to see Evil Dead - The Musical, and I was entranced by the moose puppet on the wall. I thought "Heck, it would be easy enough to make an animatronics moose to have at home", so I set out on this project.
Basic plan steps are
  • Acquire moose head puppet
  • Acquire robotic arm + servos
  • Begin programming pi - Basically can use most of the Google AYO voice pieces, need to add some references to pulse audio to capture the sound as he's speaking, to use to move the mouth
  • Assemble pieces
  • Laugh a lot
Steps completed
Moose head puppet on the way from ebay!
Robotic arm on order
Google AYO kit reformatted back to original and programming has begun!
  • easyejl
    easyejl over 6 years ago +4
    Made some modifications to the claw, and have it able to work a puppet mouth now. It's only slow because the pi is underpowered right now, I ran out of outlets. So its being powered by the USB port on…
  • easyejl
    For the claw modifications, I took out the 2 pieces circled, set the other arms to be straight and then fully tightened them. They originally were set as loose, with a locking nut so that they could bend…
  • msebok
    msebok over 6 years ago +4
    really cool progress. I was looking at the google machine and found this link, I was trying to find other methods of articulation etc...I doubt it helps or gives any ideas with your current project, but…
  • easyejl
    One thing i've learned is that this can certainly take a LOT longer than it seems up front to take a project from start to finish image
  • easyejl
    dubbie over 6 years ago in reply to easyejl
    It always takes longer. In fact, no matter how long you have it will always take longer and that is why projects are never finished, they just stop when you run out of time/get fed up/something more interesting comes along.
    Dubbie
  • easyejl
    easyejl over 6 years ago in reply to dubbie
    I'm now on my 3rd 3d printer, a resin one this time, for that reason. Started modifying a Tevo Tarantula to make it a quick change head system (to easily swap nozzle sizes) and now it sits there with the last (failed) print still on it for close to 2 years now. The elegoo mars has nothing really modifiable on it, and prints spectacularly as is.
