Animatronics
  • Animatronics
Animatronics
Blog Hey Moogle - an animatronic moose assistant
Join Animatronics to participate - click to join for free!
  • Author Author: easyejl
  • Date Created: 13 Nov 2019 8:31 PM Date Created
  • Views 7792 views
  • Likes 9 likes
  • Comments 52 comments
  • animatronicsch
easyejl
easyejl
13 Nov 2019
My wife and I went to see Evil Dead - The Musical, and I was entranced by the moose puppet on the wall. I thought "Heck, it would be easy enough to make an animatronics moose to have at home", so I set out on this project.
Basic plan steps are
  • Acquire moose head puppet
  • Acquire robotic arm + servos
  • Begin programming pi - Basically can use most of the Google AYO voice pieces, need to add some references to pulse audio to capture the sound as he's speaking, to use to move the mouth
  • Assemble pieces
  • Laugh a lot
Steps completed
Moose head puppet on the way from ebay!
Robotic arm on order
Google AYO kit reformatted back to original and programming has begun!
  • easyejl
    easyejl over 6 years ago +4
    Made some modifications to the claw, and have it able to work a puppet mouth now. It's only slow because the pi is underpowered right now, I ran out of outlets. So its being powered by the USB port on…
  • easyejl
    For the claw modifications, I took out the 2 pieces circled, set the other arms to be straight and then fully tightened them. They originally were set as loose, with a locking nut so that they could bend…
  • msebok
    msebok over 6 years ago +4
    really cool progress. I was looking at the google machine and found this link, I was trying to find other methods of articulation etc...I doubt it helps or gives any ideas with your current project, but…
  • easyejl
    Not trying to be too melodramatic about it, but that is one of software development's hardest things to conquer. How long do you pursue following one route before moving on to another? I think that Agile development often makes this worse, as since you are incrementally adding functionality, it can often take longer before you realize that the path you went down is creating more difficulties. But at some point, moogle will be answering me when I ask him what the weather will be like later image
  • msebok
    msebok over 6 years ago in reply to easyejl
    Software/any trouble shooting. I have found in my line of work you see thing repaired one way and you hope the next time you see something similar that the repair is the same.. unfortunately tractors very seldom fail the same.
  • msebok
  • msebok
    msebok over 6 years ago in reply to msebok
    hit post too soon....  and could not find an edit button?
    Its very easy to get into a loop and you just seem like you are trying the same thing over and over again. Untill a fresh idea/ or set of eyes comes into play. OR if you have another unit that you can borrow parts from for tricky issues.
