Animatronics
  • Animatronics
Animatronics
Blog Hey Moogle - an animatronic moose assistant
Join Animatronics to participate - click to join for free!
  • Author Author: easyejl
  • Date Created: 13 Nov 2019 8:31 PM Date Created
  • Views 7809 views
  • Likes 9 likes
  • Comments 52 comments
  • animatronicsch
easyejl
easyejl
13 Nov 2019
My wife and I went to see Evil Dead - The Musical, and I was entranced by the moose puppet on the wall. I thought "Heck, it would be easy enough to make an animatronics moose to have at home", so I set out on this project.
Basic plan steps are
  • Acquire moose head puppet
  • Acquire robotic arm + servos
  • Begin programming pi - Basically can use most of the Google AYO voice pieces, need to add some references to pulse audio to capture the sound as he's speaking, to use to move the mouth
  • Assemble pieces
  • Laugh a lot
Steps completed
Moose head puppet on the way from ebay!
Robotic arm on order
Google AYO kit reformatted back to original and programming has begun!
  • easyejl
    easyejl over 6 years ago +4
    Made some modifications to the claw, and have it able to work a puppet mouth now. It's only slow because the pi is underpowered right now, I ran out of outlets. So its being powered by the USB port on…
  • easyejl
    For the claw modifications, I took out the 2 pieces circled, set the other arms to be straight and then fully tightened them. They originally were set as loose, with a locking nut so that they could bend…
  • msebok
    msebok over 6 years ago +4
    really cool progress. I was looking at the google machine and found this link, I was trying to find other methods of articulation etc...I doubt it helps or gives any ideas with your current project, but…
  • easyejl
    I've found this library that seems to have most of what I want to be able to grab the currently playing level of audio
    https://github.com/pimoroni/pivumeter
    the whole problem I was having was getting all the pieces to work together. I have the rough outlines of the code "ready", but i'm facing a different difficulty. With the pi having both the audio hat + servo hat on, the audio doesn't actually play.
    I'm not sure whether this is an issue with:
    • the Raspbian for Robots distro from Dexter industries
    • what versions of alsa, pulse audio, etc are installed
    • having some hardware issue between the 2 hats
    At least if it's #3, I can scavenge the USB based servo controller off the other robot arm and remove the controller hat. I'll keep looking, but its slowed progress to next to nothing image
  • easyejl
    easyejl over 6 years ago in reply to msebok
    I had pondered and still am, whether building simple cable mechanisms and having them all go to one spot might make more sense than using a robot arm. But the robot arm seemed easier and was fun on its own
  • msebok
    msebok over 6 years ago in reply to easyejl
    I'm happy you found it interesting... quite talented fellow., I'm going to be honest, I looked through quite a bit of it before I remembered to post it.. hah.
  • easyejl
    oooh there is some really interesting stuff there. I'm going to be spending some time reading that. I like the turkey neck assembly it starts with!
  • easyejl
    I need all the help I can get image I'm now having a problem with my sound hat on the raspberry pi not working in conjunction with Dexter's Raspbian For Robots and also having the servo hat on. fun.
