Project14
Project14
Blog 18650 Li ion batteries question
  • Theme Suggestions
  • Author Author: dubbie
  • Date Created: 9 Nov 2021 4:34 PM Date Created
  • Views 2664 views
  • Comments 11 comments
  • 18650_battery
dubbie
dubbie
9 Nov 2021
I have been gifted a (broken) child's electric tricycle toy. The main problem is that the 6V 4Ah lead acid battery is defective - a collapsed cell I assume. I would like to replace this battery with Li-Ion batteries, specifically the 18650 type. I am thinking of using two 18650 to get the 6V needed (it will be a bit more at 7.2V but that will just mean the tricycle goes faster - Yeah!). However, I am finding it difficult to find suitable 18650 batteries and associated charger. It is not clear what the capacity of these 18650 batteries is. Do they vary? What is the maximum capacity? I have seen 3300 mAh mentioned but I'm having trouble identifying these batteries. I could create a parallel series arrangement of batteries to get higher currents but then I do not seem to be able to find a charger. I'd like to have separate 18650 batteries so I can use them in other things such as mobile robots.
I thought of using a 7.2V battery pack as used in cordless drills, but I cannot find any at 7.2V (or is it 7.4V - but I cannot find any of them either), plus I'm reluctant to spend a fair bit of money without knowing if it would be suitable or not.
Any advice or sources of information would be welcome.
Dubbie
  • rsjawale24
    rsjawale24 over 4 years ago +2
    Hi! The battery capacity varies as per manufacturer. Even for the 18650 type, they are available in different capacity. I recommend to buy from a vendor that gives a datasheet along with the battery. Also…
    jw0752 over 4 years ago +2
    Hi Dubbie, Unless you are paying for a quality brand name battery do not expect to get the mAh that is printed on the battery. I have tested many different East Asian Brands with ratings of 2500 mAh, 4400…
  • ralphjy
    ralphjy over 4 years ago +2
    You also need to be aware that 18650 batteries can vary in physical dimensions - especially length. Flat top batteries are about 65mm, button tops are a bit longer and protected types can be 2-4mm longer…
    beacon_dave over 4 years ago in reply to dubbie
    How about this ?
    "Compatible battery charger for 7.4V Lithium Ion Battery packs ONLY.
    Suitable for Overlander SKU 3299, 3305, 3306 and 3307, as well as other 7.4V LiIon batteries."
    https://www.overlander.co.uk/7-4v-li-ion-battery-charger.html
    "SKU#: 3299
    PCB PROTECTED 18650 SAMSUNG CELLS
    This pack comes ready-fitted with an XT60 connector and a barrel plug for charging."
    https://www.overlander.co.uk/2600mah-2s-7-4v-li-ion-rechargeable-battery-with-pcb.html
    The other SKUs appear to be for larger capacity packs configured in a series-parallel combination for increased mAh if your tricycle toy has the space for them.
    dubbie over 4 years ago in reply to robogary
    Gary,
    This was very helpful. My knowledge is slowly increasing. I may soon be at a point where I can actually buy the batteries that I want. Or get them as Christmas presents anyway.
    Dubbie
    dubbie over 4 years ago in reply to beacon_dave
    Dave,
    Thanks for this suggestion. I've had a look and it seems the sort of thing I am looking for, except that I still do not know what to use to charge them with. Is there some sort of standard charger (that I just do not seem to be able to find!)?
    Dubbie
    "... I would like to replace this battery with Li-Ion batteries, specifically the 18650 type. I am thinking of using two 18650..."
    This appears to be an of-the-shelf Li-Ion battery pack made from two 18650 cells:
    https://www.overlander.co.uk/2200mah-7-4v-2s-li-ion-battery.html
  • rsjawale24
    rsjawale24 over 4 years ago in reply to rsjawale24
    MiniZeroCam This blog by maxpowerr uses a TP4056 based Li battery charger. It's a generic one and inexpensive.
    This vendor (https://www.addicore.com/TP4056-Charger-and-Protection-Module-p/ad310.htm ) is selling one for about USD 1.2 along with the datasheet.
    Surprisingly, it's available for much lower price (INR 24 ~ USD 0.32) in some online Indian stores
