Project14
Project14
Member Updates A variable switching DC to DC buck converter using LM2576 [CC, CV][UID=da67]
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: Hesam.M
  • Date Created: 1 Aug 2019 2:01 PM Date Created
  • Views 2391 views
  • adjustable switching dc to dc converter
  • variable switching power supply
  • dc to dc buck conveter
  • lm2576 current limit
  • lm2475
  • adjustable switching supply
Hesam.M
Hesam.M
1 Aug 2019
Switching power supplies are known for high efficiency. An adjustable voltage/current supply is an interesting tool, which can be used in many applications such as a Lithium-ion/Lead-acid/NiCD-NiMH battery charger or a standalone power supply. In this article, we will learn to build a variable step-down buck converter using the popular LM2576-Adj chip.
References
LM2576 Datasheet: https://www.onsemi.com/pub/Collateral/LM2576-D.PDF
LM358 Datasheet: https://www.onsemi.com/pub/Collateral/LM358-D.PDF
LM2576 Library: https://componentsearchengine.com/part.php?partID=531545
LM358 Library: https://componentsearchengine.com/part.php?partID=671517
Altium Plugin: https://www.samacsys.com/altium-designer-library-instructions
    jw0752 over 7 years ago +1
    Thanks for an interesting build project. John
