Project14
Project14
Blog PYNQ-Z2 Getting Up and Running
  • Theme Suggestions
  • Author Author: ralphjy
  • Date Created: 20 May 2020 3:06 AM Date Created
  • Views 1069 views
  • pynq-z2
  • pynq workshop
  • pynqrunner
ralphjy
ralphjy
20 May 2020
Another great workshop with Adam Taylor today.  Adam went through creating a new Pynq overlay in Vivado.  The workshop created an overlay with a VDMA element to interface the TPG (test pattern generator) with the Processing system.
The version of the TPG IP used with the 2019.1 tools is v8.0:  https://www.xilinx.com/support/documentation/ip_documentation/v_tpg/v8_0/pg103-v-tpg.pdf
It can generate a number of interesting video patterns:
After the overlay was created it was transferred to the PYNQ-Z2 board and loaded and run via a Jupyter notebook.
In the notebook there is a section to configure the VDMA element;
and to configure the TPG:
and to display it in the notebook:
This is the color sweep pattern (0xD) @ 1280x720:
The pattern is reconfigurable using the BACKGROUND_PATTERN_ID (0x0020) Register of the TPG.  The pattern size is configurable by programming the VideoMode in the VDMA and the ACTIVE_HEIGHT (0x0010) and ACTIVE_WIDTH (0x0018) Registers in the TPG.
Before you can reconfigure the pattern you need to stop the VDMA and TPG.
This is the color bars pattern (0x9) @ 640x480:
The homework assignment is to tweak the overlay, so I'll have to give it some thought.
Very fun workshops.  I'm enjoying them.  Thanks Adam image.
  • Workshopshed
    Workshopshed over 5 years ago +2
    I'm a big fan of Jupyter notebooks after discovering them earlier in the year. They are pluggable with different kernels (the engine that runs code), I was looking at the C# and Powershell engines. I think…
  • Workshopshed
    I think they are a great way to guide a person through some code or a process and I'm thinking of introducing them into things like system monitoring or deployment.
