Project14
Project14
Member Updates Secret Santa 2021
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: dougw
  • Date Created: 29 Jan 2022 5:17 AM Date Created
  • Views 2586 views
  • Likes 9 likes
  • Comments 7 comments
  • gift review
  • aven
  • 2021
  • secret santa
Secret Santa 2021
dougw
dougw
29 Jan 2022
I was a lucky recipient of a Secret Santa gift this year so I thought I would make a quick review video of the gift to show some appreciation.
Thank you element14 and Secret Santa.
Relevant Links:
/members-area/w/documents/27332/secret-santa-giveaway-2021---holidays-on-element14?CommentId=4a0d58f4-7357-404a-b7df-02810dfdee7f
/members-area/b/entries
    beacon_dave over 4 years ago +1
    They look like electrician's scissors. I think that the serrated edge on the outside is meant to be a scraper/file for the quick cleaning up of wire ends with the two larger notches being wire strippers…
    dougw over 4 years ago in reply to ntewinkel
    I have purchased specialized cutters for this purpose a couple of times. They sort of work, but not significantly better that it is worth trying to find where I stashed them.
  • ntewinkel
    ntewinkel over 4 years ago in reply to dougw
    Thick gloves and sheet metal shears yup Smiley
    I tend to just use big scissors carefully, or with a utility knife sometimes I can slice around the item itself.
    You could buy a purpose built packaging opener, but... it's in a package you can't open without it Stuck out tongue
    package opener in package
    dougw over 4 years ago in reply to beacon_dave
    Those blister packs are just plain nasty to open. I use either a set of sheet metal shears (tin-snips) or a utility knife/scalpel to cut out a panel while avoiding the edges. It is not a bad idea to wear gloves - I always have mechanic's gloves handy at all my workstations. I bet there are many solutions others have devised since it is a problem for everyone.
    beacon_dave over 4 years ago in reply to dougw
    In general, I tend to find the handles are a bit too small and too thin on that style of scissor for prolonged use, so not sure what it would be like all day long trimming electrical wire. However, I suspect a lot will depend on the profile of the blade and how heavily it is sprung.
    Have you found a good way of safely opening clam-shell / blister packs - the ones that are hot-sealed around the entire outside edge ? I have found that off-set handle wallpaper / dress-making scissors help keep you clear of the sharp plastic edges and are typically long enough for most jobs but they aren't that well-suited to cutting plastic. Apparently you are supposed to be able to use a tin opener, but I've never got that method to work.
    The funny thing is, a few eons ago when I was a student, I had a summer job as an electrician's "helper" (which meant doing all the dirty work, while he chatted up the secretaries). But I don't recall seeing him use these types of snips. It could be that I just assumed they were scissors.
