Project14
Project14
Make a Connection EM Signal detection and transmission
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: Hoytman
  • Date Created: 10 Sep 2026 8:23 PM Date Created
  • Views 311 views
  • Comments 7 comments
  • signal
  • circuits
  • signaling
  • breadboard
  • electronics
Hoytman
Hoytman
10 Sep 2026
A sea of electromagnetic noise surrounds humanity, coming from countless electrical devices. Have you ever been curious about that noise? For my competition entry, I’ll show you how to build a simple EM detector so that you can listen in and learn more about your environment, and use it to receive an activation signal (for a motor). I have also included additional demonstration videos below. The detector circuit will require:
  • 1x LM393 voltage comparator IC
  • 2x 1M ohm resistors
  • 1x 1K ohm potentiometer
  • 1x 10K ohm potentiometer
  • 1x Battery pack
For the output circuits, I also used:
  • 1x 1uF capacitor
  • 1x stereo plug board
  • 1x PN2222 transistor
  • 1x 1N4007 Diode
  • 2x 1K resistors
  • 1x 5v DC motor
  • PC Speakers
In the following video, I will show you how to build the circuit, explain how it works, give a demo, and perform my signal presentation (note: updated 9/11).
The next videos feature a more advanced version of the detector, utilizing upgrades including a circuit board, better components, solder joints, a 3D-printed enclosure, and improved isolation. The core circuit is basically the same as the one featured earlier and uses the same principles. However, the signals are a lot cleaner. More demo videos can be found on my Youtube Playlist.
First, let’s evaluate some power supplies and see what kind of EM noises they give off during operation.
Next, let’s listen in on a Nintendo 3DS and see what it’s radiating. Notice how distinct noises emanate from different areas of the device.
Next, let’s test some audio cables and see how well their shielding works. This is a great practical use for the EM detector!
Next, let’s see if the EM detector has biofeedback capabilities. In this video, I think I heard my heartbeat.
Finally, let’s dive deeper into the proximity detection I demonstrated in the competition video. This time I’ll use a Tesla coil and evaluate how the signal changes as I move through different areas. There’s a lot more going on here that simple signal blocking.
    beacon_dave 2 months ago in reply to Hoytman
    I don't think they sell the kit anymore but the schematic is included in the construction manual:
    https://s3.eu-central-1.amazonaws.com/elektormagazine/shopify/dbl871raRDP5tKGHJ84lLuQDOZa1LMuf.pdf#page=14
    It may help you get that side-by-side comparison.
  • Hoytman
    Hoytman 2 months ago in reply to beacon_dave
    That is super interesting.  The output of their circuit sounds similar, but I bet it's far more sensitive.  It look's like they are using amplification to make a tiny signals audible, which is a bit different that my design, which detects how voltages crossing a threshold.  I think their output is analog and responds to magnetic and EM energy.  My circuit's output is digital and responds well to EM and stationary static charge (it's a very poor magnetic field detector.). Another interesting difference is that my circuit can produce audio without amplification (but not very good audio.) I would love to do a side by side comparison of both devices with a spectrum analyzer!
    I recall a long time ago an Elektor project referred to this as 'E-smog', which I thought was quite appropriate name for it.
    They had a more basic detector which they called TAPIR - (Totally Archaic but Practical Interceptor of Radiation)
    https://www.youtube.com/watch?v=M-q37LKKzrI
    DAB 2 months ago in reply to Hoytman
    That depends upon what type of inductor they are and what affects you want them to create.
    Try putting them on the input, both in parallel and in series to see what changes and at what frequencies.
    You can then do the same on the output.
    Just keep in mind that you quickly change the impedance's wherever you place them.
    So I would do some quick tests to find out their values and then calculate their effect.
  • Qbit
    Qbit 2 months ago
    Very interesting project, I will also try this out.
