Project14
Project14
Show and Tell! AI Voice Mood Lighting System
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: karthickiot
  • Date Created: 30 Aug 2026 5:20 PM Date Created
  • Views 206 views
  • rgb led
  • Vosk Model
  • KEYWORD DETECTION
  • voice assistance
  • ai
  • speech recognition
karthickiot
karthickiot
30 Aug 2026
Hello everyone.
My Project14 project is called “AI Voice Mood Lighting System.” The basic idea is simple: I speak a word → the system recognizes it → the word is mapped to an emotion or situation → the RDK X5 changes an RGB LED to the corresponding color.
For example:
  • Danger → Red Red circle
  • Freshness → Green
  • Peaceful → Blue Large blue circle
  • Happiness → Yellow
  • Sweetness → Cyan
  • Honesty → White White circle
  • Royalty → Magenta
  • Funny → Color-changing dance mode Rainbow
  • Sleep → Light OFF
This project interesting due to the speech-recognition part works offline using Vosk, while the RDK X5 handles the physical RGB LED.
What Inspired Me?
I wanted to build something that could demonstrate how a person can interact naturally with an embedded system. Instead of pressing a button or typing a command, I wanted to use voice. The idea developed from a simple question: Can I use voice recognition to control a physical RGB LED using the RDK X5? I also wanted the project to work without depending on the internet. That led me to combine: Voice + Offline AI + Embedded Hardware + RGB Visualization. The RGB LED gives an immediate visual response.
For example, if I say: “Danger” the system recognizes the keyword and the RDK X5 changes the LED to red. If I say: “Peaceful” the LED changes to blue. This makes the project easy to demonstrate and understand.
Project Architecture
The project has two major parts.
PC side
The PC is responsible for:
  • Capturing microphone audio
  • Running the Vosk offline speech-recognition model
  • Converting speech into text
  • Detecting important keywords
  • Mapping keywords to colors
  • Sending HTTP commands to the RDK X5
  • Providing voice feedback through the PC speaker
RDK X5 side
The RDK X5 is responsible for:
  • Running the Flask server
  • Receiving HTTP commands
  • Controlling GPIO pins
  • Driving the RGB LED
The complete architecture is:
              HUMAN VOICE
            PC MICROPHONE
         VOSK OFFLINE MODEL
          Speech Recognition
          KEYWORD DETECTION
      Danger     Peaceful   Happiness
       RED        BLUE       YELLOW
             HTTP REQUEST
          RDK X5 FLASK SERVER
               GPIO PINS
                RGB LED
Hardware Used
The main hardware components are:
  • RDK X5 development kit
  • Common-anode RGB LED
  • Current-limiting resistors
  • Jumper wires
  • PC or laptop
  • Microphone
  • Network connection between the PC and RDK X5
The RGB LED channels are connected as follows:
RGB Channel RDK X5 GPIO
Red GPIO 31
Green GPIO 36
Blue GPIO 37
I used board numbering with:
GPIO.setmode(GPIO.BOARD)
Each RGB channel is connected through an appropriate current-limiting resistor.
Common-Anode RGB LED
One important hardware detail in my project is that the RGB LED is common-anode. A common-anode RGB LED has three individual color channels:
  • Red
  • Green
  • Blue
By controlling these three channels, I can create several colors.
For example:
Red + Green       = Yellow
Green + Blue      = Cyan
Red + Blue        = Magenta
Red + Green + Blue = White
However, common-anode LEDs use inverted logic.
For my setup:
GPIO LOW  → LED ON
GPIO HIGH → LED OFF
Therefore, to turn on red:
RED   → LOW  → ON
GREEN → HIGH → OFF
BLUE  → HIGH → OFF
This produces red.
To make the programming easier, I created a common function that handles this inverted logic. Conceptually: GPIO.LOW if red else GPIO.HIGH This prevents me from having to manually remember the reversed logic for every color.
RGB Color System
I created functions for the different colors.
The logical mapping is:
DANGER      → RED
FRESHNESS   → GREEN
PEACEFUL    → BLUE
HAPPINESS   → YELLOW
SWEETNESS   → CYAN
HONESTY     → WHITE
ROYALTY     → MAGENTA
SLEEP       → OFF
FUNNY       → COLOR CHANGING
This gives the RGB LED the role of a simple visual emotion and situation indicator.
Bill of Materials (BOM) — Offline Voice-Controlled Emotion RGB Assistant
S.No. Component Specification / Purpose Qty.
1 RDK X5 Development Kit Main embedded controller, Flask server & GPIO control 1
2 Common-Anode RGB LED Displays different emotion/status colors 1
3 Resistors Current-limiting resistors for RGB LED channels 3
4 Jumper Wires GPIO and power connections 6–10
5 Breadboard Prototype circuit assembly 1
6 PC / Laptop Offline voice recognition and command processing 1
7 Microphone Captures voice commands 1
8 Network Connection PC Left right arrow RDK X5 communication using HTTP 1
9 USB Cable / Power Supply Power and/or connection for RDK X5 1
10 RDK X5 compatible power supply Provides power to the development kit 1
Software / AI Components
S.No. Software Purpose
1 Python Main programming language
2 Vosk Offline speech recognition
3 vosk-model-small-en-in-0.4 English-India offline speech model
4 Sounddevice Microphone audio capture
5 Flask HTTP server running on RDK X5
6 Requests PC-to-RDK X5 HTTP communication
7 RPi.GPIO / compatible GPIO library RGB LED GPIO control
First Development Stage – Testing the LED
I did not start by connecting everything together. Instead, I developed the project in stages. First, I tested the RGB LED independently. I tested:
OFF
RED
GREEN
BLUE
YELLOW
CYAN
MAGENTA
WHITE
OFF
This was important because I wanted to confirm that the GPIO connections and common-anode logic were correct before adding networking and voice recognition.
Building the RDK X5 LED Server
After confirming that the LED worked, I created a Python Flask server on the RDK X5.
from flask import Flask, request
import Hobot.GPIO as GPIO
import time
import atexit
# FLASK SERVER
app = Flask(__name__)
# GPIO SETTINGS
RED = 31
GREEN = 36
BLUE = 37
GPIO.setup(
    RED,
    GPIO.OUT
GPIO.setup(
    GREEN,
    GPIO.OUT
GPIO.setup(
    BLUE,
    GPIO.OUT
# COMMON ANODE RGB LED
# LOW = ON
# HIGH = OFF
def led_off():
    GPIO.output(RED, GPIO.HIGH)
    GPIO.output(GREEN, GPIO.HIGH)
    GPIO.output(BLUE, GPIO.HIGH)
def set_color(red, green, blue):
    GPIO.output(
        RED,
    GPIO.output(
        GREEN,
        GPIO.LOW if green else GPIO.HIGH
    GPIO.output(
        BLUE,
        GPIO.LOW if blue else GPIO.HIGH
# COLORS
def red():
    set_color(1,0,0)
def green():
    set_color(0,1,0)
def blue():
    set_color(0,0,1)
def yellow():
    set_color(1,1,0)
def cyan():
    set_color(0,1,1)
def magenta():
    set_color(1,0,1)
def white():
    set_color(1,1,1)
# COMMAND HANDLER
def control_led(color):
    color = color.lower()
    if color == "red":
        red()
    elif color == "green":
        green()
    elif color == "blue":
        blue()
    elif color == "yellow":
        yellow()
    elif color == "cyan":
        cyan()
    elif color == "magenta":
        magenta()
    elif color == "white":
        white()
    elif color == "off":
        led_off()
    else:
        return False
    return True
# API ROUTES
@app.route("/led")
def led_control():
    try:
        color = request.args.get(
            "color"
        if color is None:
            return "Missing color",400
        print(
            "Received:",
            color
        result = control_led(
            color
        if result:
            return "OK"
        else:
            return "Invalid color"
    except Exception as e:
        print(
            "LED ERROR:",
            e
        return "ERROR"
@app.route("/status")
def status():
    return "RDK RGB SERVER OK"
# CLEAN EXIT
def cleanup():
    print(
        "GPIO cleanup"
    led_off()
    GPIO.cleanup()
atexit.register(
    cleanup
# START
led_off()
print("==============================")
print("RDK X5 RGB LED SERVER READY")
app.run(
    host="0.0.0.0",
    port=5000,
    threaded=True
The server is called: led_server.py, It listens on: Port 5000, The main endpoint is: /led, The color is provided as a URL parameter. For example:  /led?color=red , The RDK X5 receives the request and controls the GPIO pins accordingly. I also created a: /status endpoint. This allows me to check whether the LED server is running. The server is configured to accept network connections so that the PC can communicate with the RDK X5.
Testing Network Communication
Before adding voice recognition, I tested the network communication separately. The process was:
PC
 │ HTTP command
RDK X5 Flask Server
GPIO
RGB LED
For example, the PC can request:
color=red
The RDK X5 receives it and turns the LED red. I repeated this process for the other colors. This staged development helped me identify problems more easily.
Adding Offline Voice Recognition
Once the hardware and network control were working, I added voice recognition. For this, I used the Vosk offline speech-recognition engine. The model I used is: vosk-model-small-en-in-0.4. The PC microphone captures the audio using Python's sound device library. The audio configuration is:
Sample rate: 16000 Hz
Channels:    1
Format:      int16
The audio is placed into a queue and processed by Vosk. Vosk returns recognized text, which my Python program then analyzes. The important point is that the basic speech-recognition process happens locally, rather than sending my voice to a cloud speech-recognition service.
Keyword Detection
The system does not need to understand an entire conversation. It mainly needs to identify important keywords. For example: “happiness” ↓ yellow ↓ HTTP request ↓ RDK X5 ↓ RGB = Yellow Similarly: “peaceful” ↓ blue ↓ RDK X5 ↓ RGB = Blue I convert the recognized text to lowercase and then check for keywords. I also added variations to make the system more tolerant. For example:
happy / happiness
peace / peaceful
fresh / freshness
danger / dangerous
sweet / sweetness
honest / honesty
royal / royalty
This is useful because speech-recognition models do not always return exactly the word that I spoke.
START and STOP Control
I also added a simple activation mechanism. The system starts in an inactive state: active = False When I say: START the system becomes active. When I say: STOP the system becomes inactive and the LED is turned off. This prevents random conversations or background speech from continuously controlling the LED. It also makes the demonstration more controlled.
Funny / Dance Mode
I wanted to add something more interesting than just static colors. So I created a special command: FUNNY When I say FUNNY, the LED enters a small dance-light mode. It cycles through:
Red
Green
Blue
Yellow
Cyan
Magenta
White
The sequence repeats several times with a short delay. Finally, the LED turns off. This gives the project a more interactive and entertaining demonstration.
Sleep Command
I also added: SLEEP The purpose is simple. When the system recognizes the sleep command: SLEEP ↓ LED OFF This gives me a direct voice command for switching off the visual output.
import json
import queue
import requests
import win32com.client
import time
import os
import sounddevice as sd
from vosk import Model, KaldiRecognizer
# RDK X5 SETTINGS
RDK_IP = "192.162.6.167"   this should change according to your network
LED_URL = f"http://{RDK_IP}:5000/led"
# OFFLINE VOSK MODEL
MODEL_PATH = os.path.join(
    os.path.dirname(__file__),
    "vosk-model-small-en-in-0.4"
print()
print("======================================")
print("Loading offline speech recognition...")
print()
if not os.path.exists(MODEL_PATH):
    print("ERROR: Vosk model not found.")
    print()
    print("Expected model folder:")
    print(MODEL_PATH)
    print()
    input("Press Enter to exit...")
    exit()
model = Model(
    MODEL_PATH
recognizer = KaldiRecognizer(
    model,
    16000
print(
    "Offline speech recognition ready."
print()
# LAPTOP SPEAKER
speaker = win32com.client.Dispatch(
    "SAPI.SpVoice"
speaker.Rate = -1
speaker.Volume = 100
def speak(text):
    print(
        "LAPTOP SPEAKER:",
        text
    speaker.Speak(
        text
# SEND COLOR COMMAND TO RDK
def send_color(color):
    try:
        response = requests.get(
            LED_URL,
            params={
                "color": color
            timeout=3
        print(
            "RDK:",
            response.text
        return True
    except requests.exceptions.RequestException as e:
        print()
        print(
            "RDK CONNECTION ERROR:"
        print(
            e
        print()
        speak(
            "RDK connection failed"
        return False
# FUNNY / DANCE LIGHTS
def funny_lights():
    colors = [
        ("red", "Red"),
        ("green", "Green"),
        ("blue", "Blue"),
        ("yellow", "Yellow"),
        ("cyan", "Cyan"),
        ("magenta", "Magenta"),
        ("white", "White")
    print()
    print(
        "FUNNY / DANCE LIGHTS STARTED"
    print()
    # Repeat the color sequence 3 times
    for repeat in range(3):
        for color, name in colors:
            send_color(
                color
            print(
                "FUNNY:",
                name
            time.sleep(
                0.5
    # Turn all lights OFF after dance
    send_color(
        "off"
    speak(
        "Funny dance completed"
# MICROPHONE AUDIO QUEUE
audio_queue = queue.Queue()
def audio_callback(
    indata,
    frames,
    time_info,
    status
    if status:
        print(
            "AUDIO STATUS:",
            status
    audio_queue.put(
        bytes(indata)
# SYSTEM STATUS
active = False
# PROCESS VOICE COMMAND
def process_command(command):
    global active
    command = command.lower().strip()
    print()
    print(
    print(
        "VOSK HEARD:",
        command
    print(
    # NORMALIZE COMMON SPEECH
    command = command.replace(
        "wake up",
        "wakeup"
    # START
    if command == "start":
        active = True
        speak(
            "Voice control started"
        print(
            "SYSTEM STATUS: ACTIVE"
        return
    # STOP
    if command == "stop":
        active = False
        send_color(
            "off"
        speak(
            "Voice control stopped"
        print(
            "SYSTEM STATUS: INACTIVE"
        return
    # WAIT FOR START
    if active == False:
        print(
            "Voice control is OFF."
        print(
            "Say start to activate."
        return
    # DANGER → RED
    if (
        "danger" in command
        or "dangerous" in command
        if send_color(
            "red"
            speak(
                "Danger. Red color is on"
        return
    # FRESHNESS → GREEN
    elif (
        "freshness" in command
        or "fresh" in command
        if send_color(
            "green"
            speak(
                "Freshness. Green color is on"
        return
    # PEACEFUL → BLUE
    elif (
        "peaceful" in command
        or "peace" in command
        if send_color(
            "blue"
            speak(
                "Peaceful. Blue color is on"
        return
    # HAPPINESS → YELLOW
    elif (
        "happiness" in command
        or "happy" in command
        if send_color(
            "yellow"
            speak(
                "Happiness. Yellow color is on"
        return
    # SWEETNESS → CYAN
    elif (
        "sweetness" in command
        or "sweet" in command
        if send_color(
            "cyan"
            speak(
                "Sweetness. Cyan color is on"
        return
    # HONESTY → WHITE
    elif (
        "honesty" in command
        or "honest" in command
        if send_color(
            "white"
            speak(
                "Honesty. White color is on"
        return
    # ROYALTY → MAGENTA
    elif (
        "royalty" in command
        or "royal" in command
        if send_color(
            "magenta"
            speak(
                "Royalty. Magenta color is on"
        return
    # FUNNY → DANCE / ALL COLORS
    elif (
        "funny" in command
        or "fun" in command
        speak(
            "Funny mode started"
        funny_lights()
        return
    # SLEEP → ALL LIGHTS OFF
    elif "sleep" in command:
        if send_color(
            "off"
            speak(
                "Sleep. All lights are off"
        return
    # EXIT
    elif "exit" in command:
        speak(
            "Program closed"
        raise KeyboardInterrupt
    # UNKNOWN COMMAND
    else:
        print(
            "Command not recognized:"
        print(
            command
        speak(
            "Command not recognized"
# PROGRAM START
print()
print("RDK X5 OFFLINE EMOTION RGB ASSISTANT")
print()
print(
    "RDK IP:",
    RDK_IP
print()
print(
    "VOICE COMMANDS"
print(
print(
    "START     -> Activate system"
print(
    "STOP      -> Deactivate system"
print(
    "DANGER    -> Red"
print(
    "FRESHNESS -> Green"
print(
    "PEACEFUL  -> Blue"
print(
    "HAPPINESS -> Yellow"
print(
    "SWEETNESS -> Cyan"
print(
    "HONESTY   -> White"
print(
    "ROYALTY   -> Magenta"
print(
    "FUNNY     -> Dance all colors"
print(
    "SLEEP     -> All lights OFF"
print(
    "EXIT      -> Close program"
print(
print()
speak(
    "System ready. Say start"
# START MICROPHONE
try:
    with sd.RawInputStream(
        samplerate=16000,
        blocksize=8000,
        dtype="int16",
        channels=1,
        callback=audio_callback
        print()
        print(
        print(
            "MICROPHONE READY"
        print(
        print()
        print(
            "Say START to activate."
        print(
            "Say STOP to deactivate."
        print()
        while True:
            data = audio_queue.get()
            if recognizer.AcceptWaveform(
                data
                result = json.loads(
                    recognizer.Result()
                command = result.get(
                    "text",
                if command:
                    process_command(
                        command
# KEYBOARD INTERRUPT
except KeyboardInterrupt:
    print()
    print(
        "Program stopped."
# PROGRAM ERROR
    print()
    print(
        "PROGRAM ERROR:"
    print(
        e
    print()
# CLEANUP
finally:
    try:
        send_color(
            "off"
    except Exception:
        pass
    print()
    print(
        "Voice control closed."
    print()
PC-to-RDK X5 Communication
The PC communicates with the RDK X5 using HTTP. The Python program sends a request similar to:
requests.get(
    LED_URL,
    params={"color": color},
    timeout=3
The important advantage of this design is that the PC does not directly control the RDK X5 GPIO.
Instead:
PC
 │ HTTP
Flask API
GPIO
RGB LED
This creates a clean separation between the software and hardware. I also added timeout and exception handling so that if the RDK X5 cannot be reached, the PC program can report the connection problem instead of simply crashing.
A Major First Challenge – Offline Speech Recognition
The biggest challenge I faced was offline keyword recognition accuracy. Initially, I expected the offline model to recognize my keywords consistently. But during testing, I discovered that some words were not recognized correctly every time. The result could be affected by:
  • Pronunciation
  • Microphone quality
  • Background noise
  • Speaking distance
  • Speaking volume
  • The vocabulary of the model
For example, I might speak a keyword correctly, but Vosk could sometimes return a different word. That becomes a problem because my application needs to detect a specific keyword before it can select a color.
Offline vs Online Recognition
During development, I also compared the offline recognition with an online speech-recognition approach. In my testing, the online system performed better for some of my phrases. It could recognize certain words more accurately and consistently. However, I specifically wanted this project to demonstrate offline operation. If I simply replaced Vosk with an online service, I would lose an important part of my project concept. So I treated this as an engineering trade-off:
ONLINE RECOGNITION
      ├── Better recognition in my testing
      └── Requires internet/cloud service
OFFLINE VOSK
      ├── Local processing
      ├── No cloud dependency
      └── More challenging recognition
Instead of hiding this limitation, I used it as a learning opportunity.
Improved the Recognition
I added multiple variations for some keywords. For example:
happy / happiness
peace / peaceful
fresh / freshness
danger / dangerous
This means the program does not depend on only one exact form of a word. I also kept the speech-recognition system separate from the LED-control system. That means I can improve the recognition algorithm later without changing the RDK X5 GPIO implementation.
Second Challenge – Common-Anode Logic
Another challenge was understanding the behavior of the common-anode RGB LED. With a common-cathode LED, the logic is different. But with my common-anode LED: LOW = ON, HIGH = OFF Initially, I had to make sure that my software matched the electrical behavior. I solved this by creating a dedicated set_color() function. This made the rest of the program much easier to understand. Instead of thinking about GPIO levels everywhere, I can simply say: set_color(1,0,0) for red, or: set_color(0,1,1) for cyan.
Third Challenge – Network Communication
The PC and RDK X5 also need to communicate over the network. The PC sends the HTTP command to the RDK X5. Therefore, both devices need to be reachable on the same network. I used an IP address for the RDK X5 and port 5000 for the Flask server. I also added a timeout to the HTTP request. This taught me that even when individual components work correctly, the complete system can still fail because of communication problems.
Final Demonstration
For my final demonstration, I will show the complete system. Step 1 Start the RDK X5 Flask LED server. Step 2 Start the PC voice-control program. Step 3 Say: START The system becomes active. Step 4 Say: DANGER The RDK X5 receives the command. The LED becomes: Red circle RED Step 5 Say: PEACEFUL The LED changes to: Large blue circle BLUE Step 6 Say: HAPPINESS The LED changes to: YELLOW Step 7 Say: FUNNY The LED starts cycling through multiple colors. Rainbow Dance Mode Step 8 Say: SLEEP The LED turns off. The complete demonstration is:
VOICE
OFFLINE SPEECH RECOGNITION
KEYWORD DETECTION
COLOR SELECTION
HTTP COMMAND
RDK X5
GPIO
RGB LED
Demonstration Video
I also created a demonstration video of the project:
Future Improvements
The RGB LED is only the first stage of my idea. I would like to develop this prototype into a more useful AI-assisted care and interaction device.
1. Better Offline Recognition
I would like to investigate:
  • Better Vosk models
  • Smaller command vocabularies
  • More robust keyword matching
  • Better noise handling
Instead of allowing a large vocabulary, I could focus recognition specifically on the commands required by my project.
2. Better Noise Handling
I would like to test the system with:
  • Background noise
  • Different microphones
  • Different speaking distances
  • Different speaking volumes
  • Multiple speakers
This would help determine how reliable the system is in real-world conditions.
3. Camera-Based Mood Detection
A future version could include a camera.
The system could combine:
Voice + Facial Expression
to obtain more information about a person's mood.
For example:
VOICE
CAMERA
MOOD INFORMATION
AI PROCESSING
APPROPRIATE RESPONSE
4. Motion Sensor
I would also like to add a motion sensor. This could help the system understand whether a person is moving or whether unusual activity is occurring.
5. Alerts
For a command such as DANGER, a future version could do more than turn the LED red.
It could potentially:
DANGER
RED LED
ALARM
NOTIFICATION
CAREGIVER ALERT
6. More Visual Effects
I could also add:
  • Breathing colors
  • Blinking
  • Smooth color transitions
  • Emergency flashing
  • Rainbow effects
  • Emotion-specific animations
This would make the RGB output more expressive.
Long-Term Vision
long-term goal is to develop the prototype into a small AI-assisted care and interaction device.
The future concept could look like this:
                    PERSON
           VOICE              CAMERA
                 MOTION SENSOR
                │   RDK X5    │
                │     AI      │
           RGB       ALERT     OTHER
           LED       SYSTEM    DEVICES
                USER / CAREGIVER
The device could eventually combine different types of information instead of relying only on one voice keyword.
Possible Applications
The concept could potentially be useful in areas such as:
A simple interactive device could provide visual feedback when a child speaks a command.
Elder Care
Voice commands could provide a simple interface for communicating basic needs or situations.
Patient Assistance
In a future and more carefully validated version, voice commands could help communicate simple requests or situations when normal communication is difficult.
These are future possibilities, not capabilities of my current prototype.
What I Learned
The most important thing I learned from this project is that building an AI system is not just about making the model work once. There is a big difference between: “The model can recognize speech.” and “The model can reliably recognize the exact commands my application needs.” My testing showed that online speech recognition could be more accurate for some phrases, while the offline model gave me the advantage of local processing and no cloud dependency.
This taught me about:
  • Speech-recognition limitations
  • Vocabulary
  • Microphone input
  • Background noise
  • Keyword matching
  • Error handling
  • HTTP communication
  • Flask servers
  • GPIO control
  • RGB electronics
  • System architecture
  • The trade-offs between offline and online AI
I also learned the importance of developing a project in stages. First I tested the LED. Then I tested the network. Then I added voice recognition. Finally, I connected everything together. This made it much easier to identify and solve problems.
Conclusion
My current system demonstrates: Voice → Offline AI → Keyword → HTTP → RDK X5 → GPIO → RGB LED
It combines: Python + Vosk + Sounddevice + Flask + HTTP + GPIO + RGB LED
The most important part of this project for me was not simply making an LED change color. It was understanding the complete journey from human speech to physical hardware, and learning how to solve the practical problems along the way. The main challenge I am continuing to work on is improving the reliability of offline keyword recognition. In the future, I would like to expand the project from: Voice + RGB LED into: Voice + Camera + Motion → AI Understanding → Useful Action
My ultimate goal is to develop this prototype into a more robust, standalone, AI-assisted device that can provide simple and useful interaction for people.
Thank you.
  • kmikemoo
    kmikemoo 2 months ago
    Cool project.  I admire the honest functionality video where the AI did not recognize all of the commands.  Well done regardless. Thumbsup
  • TheRehn
    TheRehn 2 months ago
    This is such a cool project and so well explained, using offline VOSK speech recognition seems to open up options for running it on dev board. Now wondering if it would be possible to have a 'mood badge' you could set the colour of by voice Thinking
