Project14
Project14
Show and Tell! PLC with PSoC
  • News
  • Member Updates
  • Competitions
  • Theme Suggestions
  • Author Author: Em0ke
  • Date Created: 28 Jul 2026 11:38 AM Date Created
  • Views 346 views
  • Comments 5 comments
PLC with PSoC
Em0ke
Em0ke
28 Jul 2026
PLC with PSoC
This PLC board is designed using a Cypress System-on-Chip (SoC) microcontroller for industrial automation and embedded control applications. The Cypress SoC integrates a microcontroller with programmable analog and digital peripherals on a single chip, making the system compact and efficient. The PLC is capable of monitoring multiple digital input signals and controlling several relay outputs according to the programmed logic. The relay outputs provide electrical isolation, allowing the board to safely switch external loads such as motors, lamps, solenoid valves, and contactors. Input and output connections are made through terminal blocks, making installation and maintenance simple. Driver ICs on the board interface the microcontroller with the relays to ensure reliable operation. LEDs indicate the status of the power supply and relay outputs, helping users monitor the system during operation. The DIP switch can be used to configure different operating modes or system settings. The PCB layout is compact and integrates the controller, relay drivers, relays, and supporting components on a single board. The Cypress SoC executes the control program stored in its memory and processes input signals in real time. This PLC is suitable for industrial process control, machine automation, and educational projects. Its flexible architecture allows new control functions to be added through software without major hardware modifications. The combination of reliable hardware and programmable control makes the system versatile and cost-effective. Overall, this PLC demonstrates how a Cypress System-on-Chip microcontroller can be used to develop a reliable, efficient, and flexible industrial control system.
  • Em0ke
    Em0ke 4 months ago in reply to cstanton +2
    Yes
  • Em0ke
    Em0ke 3 months ago in reply to cstanton
    no
  • cstanton
    cstanton 4 months ago in reply to Em0ke
    Impressive, is it currently in operation anywhere?
    DAB 4 months ago in reply to Em0ke
    I like it.
    The SoC provides a lot of capability that you can build features for control projects.
  • Em0ke
    Yes
  • cstanton
    Hold on, you designed and made a PLC with a Cypress SoC?
