Build a Present
  • Build a Present
Build a Present
Blog Blind Stick
  • Author Author: rpiloverbd
  • Date Created: 20 Jan 2022 1:18 PM Date Created
  • Views 2007 views
  • Likes 11 likes
Blind Stick
rpiloverbd
rpiloverbd
20 Jan 2022
Blind Stick
I have made a simple blind stick. This can be helpful to blind people. I have used a SONAR sensor, an Arduino UNO, some jumper wires and a buzzer.
Arduino UNO is the brain of this project. The SONAR sensor  and a buzzer is connected to the arduino UNO. The Arduino takes reading from the SONAR sensor
When the nearest obstacle is less than  25 cm away,  the Arduino makes the buzzer pin High. The buzzer starts making a sound.  Thus the user can be alert and alter their way. I attached the circuit to a white stick-like thing that was available at home.
Parts list
Arduino UNO x 1
HCSR04 SONAR sensor x 1
Buzzer x 1
Walking Stick x 1
Jumper wires
Double sided tapes
Connection:
Arduino UNO SONAR Sensor
VCC VCC
GND GND
Trig 2
Echo 3
Arduino Uno Buzzer
11 +
GND -
Code
#define trigPin 2
#define echoPin 3
#define buzzerPin 11
// Define variables:
float duration=0.00;
float distance=0.00;
void setup() {
  // Define inputs and outputs:
  pinMode(trigPin, OUTPUT);
  pinMode(buzzerPin, OUTPUT);
  pinMode(echoPin, INPUT);
  //Begin Serial communication at a baudrate of 9600:
  Serial.begin(9600);
void loop() {
  // Clear the trigPin by setting it LOW:
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Trigger the sensor by setting the trigPin high for 10 microseconds:
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Read the echoPin, pulseIn() returns the duration (length of the pulse) in microseconds:
  duration = pulseIn(echoPin, HIGH);
  // Calculate the distance:
  distance = duration /58.82 ;
  // Print the distance on the Serial Monitor (Ctrl+Shift+M):
  Serial.print("Distance = ");
  Serial.print(distance);
  Serial.println(" cm");
  delay(1000);
  if(distance<=25)
    digitalWrite(buzzerPin ,HIGH);
  else
    digitalWrite(buzzerPin ,LOW);
  • robogary
    robogary over 4 years ago
    nice thoughtful project.
  • rpiloverbd
    rpiloverbd over 4 years ago in reply to beacon_dave
    Thanks for such an informative suggestion, sir. It will surely help me improve my work. God bless you.
    beacon_dave over 4 years ago
    Perhaps a compass with audible/haptic feedback might be useful addition ?
    I've encountered visually impaired people who have lost their sense of orientation in unfamiliar open spaces. A compass would perhaps help get them heading in a known direction again.
    This wearable acoustic wayfinder with haptic feedback project based on the 'Hoover' cane may be of interest:
    Sonar navigation
    https://youtu.be/uGR3G30FyMc
    Acoustic wayfinding appears to be a popular final project for students studying microcontrollers at Cornell.
    sonar scanner with audio localization
    https://youtu.be/YrCAXayGJN0
    Bat Hat
    https://youtu.be/xsL3UTauHmk
    personal collision detector
    https://youtu.be/tLfEd7xI-BE
