Build a Present
  • Build a Present
Build a Present
Blog Light-up blog # 2: Components for the cube
  • Author Author: alrms
  • Date Created: 16 Dec 2021 2:36 PM Date Created
  • Views 906 views
  • Likes 9 likes
  • Cube
  • light
  • game
  • led
  • buildapresentch
  • 3d print
alrms
alrms
16 Dec 2021
These will be the initial components that I'll be using for a single cube:
  • 1 red 8x8 LED matrix
  • 4 RGB LEDs
  • 1 Arduino Uno or Nano
  • 1 HC-05 Bluetooth module
  • Jumper wires
  • 4 pushbuttons
  • 2 Max7219 ic
  • 1 7-segment LED
  • 1 tilt switch
  • resistors (220 ohms)
Two of these cubes will be created and sync together via Bluetooth.
This list is open to revision as the project will progress. Updates on these changes will be reflected in future blogs..
What's next?
I'll be moving with developing the program for controlling and using each components. Some components I'll need to learn how to use along the way. I will do my best to relay my thought process for these in the next blogs.
