Build a Present
  • Build a Present
Build a Present
Forum Just received a Build a Present Shopping Cart!
  • Subscribers 30 subscribers
  • Views 1929 views
  • shopping cart
  • buildapresent
  • project14
  • blessed
ntewinkel
ntewinkel over 4 years ago
While we were out yesterday, a BIG box arrived on our doorstep!!
Look! it's half the size of the delivery lady!
security cam big box delivery
Opening it up revealed all kinds of fun little packages... along with a long crumpled ream of packing paper the cats will get to play with!
Project14 Shopping Cart Box
Inside of all the little packages (which adds to the excitement, that unboxing-birthday-presents feeling), all kind of future projects emerged...
project14 shopping cart goodies
I was able to choose quite a variety of items! :)
I started with some tools to outfit my bench, including better quality test leads for my multi-meter. Some of mine seem to have become untrustworthy over time. The stepped drill bits appear to be handy for adding right-sized holes to project boxes to fit everything from LEDs to big button switches.
I also picked up an IR thermometer to use with my ongoing hummingbird feeder heater project, and to help with some heat pump issues I've been having (hopefully that will be resolved soon).
Along the same lines of temperature tracking, I was happy to find a little weather station. Very cool, I didn't realize Newark sold those. My very old unit just quit working over this winter, so the timing is perfect.
I also picked up some more 3D printer filament colours. Prior to this I've mainly been using white PLA for everything. I had some green ABS I got cheaply locally a while back but I've found that very difficult to print with, so I don't use it often. It'll be fun to try out the shiny gold and wood coloured filaments Slight smile
I've seen a lot of good reviews about the Wago lever-nut electrical connectors, so I picked up a variety of those, both for my small electrical projects as well as for making it easier to update / repair /replace things like smart switches and light fixtures in my house - they seem to be just the right thing to safely connect solid house wire with the usually stranded fixture wire, and then to make it easy to disconnect and reconnect over time. Up to now I've been using the screw-on wire nuts, which work well too but can take a bit more finessing.
The rest are parts directly intended for future projects - some switches, displays, transistors, and sensors. I found a stepper motor that I hope to use for some robotic thing, and I noticed they even had a water valve! I've had some ideas around projects with those things, so I included two.
And of course, I had to try out the Pi Pico! Interesting how it's packaged like it's off a big reel Smiley
I'm feeling super blessed to be part of this forum!
I just realized I've been part of the element14 community for over a decade already, and element14 has been supporting my tech hobby for every single one of those years.
The people, too, are amazing - that includes all of us civilians as well as those driving the machinery behind the scenes!
Without all of your positive support over the years I might not have been doing all of these cool hobby things I'm doing now Slight smile
Thank you element14!
You never cease to amaze me with your generosity and positive support Slight smile
-Nico
  • javagoza
    javagoza over 4 years ago +3
    Thanks for sharing your shopping list. For me it is the most difficult part of project14 to make the decision of which bonbon to choose.
    shabaz over 4 years ago +3
    It's always interesting to see what parts I'm missing, by seeing other people's shopping : ) Looks like you've got a fun weekend exploring it all : ) Nice set of stepped drills!
    dubbie over 4 years ago +1
    Looks like a good selection of 'bits'. I too have just this week purchased some blue filament for my 3D printer to see what it might be like, after four years of just white. I only use my manufacturer…
  • javagoza
    Looks like a good selection of 'bits'. I too have just this week purchased some blue filament for my 3D printer to see what it might be like, after four years of just white. I only use my manufacturer specified filament which is much more expensive but I have enough difficulty as it is getting good prints without complicating matters with cheaper filaments. Still, I have been thinking of getting a new 3D printer in order to get a larger print area so I might change my mind if I do that. I look forward to seeing your different colours.
    Dubbie
    Jan Cumps over 4 years ago in reply to dubbie
    In my case you have to take that literally Slight smile.
    I had 3 soldering bits in my p14 cart:
