Circuit Prototype Techniques
  • Circuit Prototype Techniques
Blog Circuit Prototyping
Join Circuit Prototype Techniques to participate - click to join for free!
  • Author Author: rsc
  • Date Created: 24 Jan 2022 3:20 AM Date Created
  • Views 7321 views
  • Likes 13 likes
  • wire-wrap
  • Protyping
  • circuitprototypingch
  • circuitprototypetechniques
Circuit Prototyping
rsc
rsc
24 Jan 2022
I keep a bunch of small breadboards around for prototyping.
There are three types of circuit prototyping methods I tend to use.
The first is just a simple breadboard.
https://uk.farnell.com/global-specialties/gs-400/breadboard-abs-35-56mm-x-83-82mm/dp/2850738
I like having the power rails on either side, although it gets confusing with dual voltage power supplies.
Here's one of my current Arduino projects:
The second prototyping method I like to use is wire-wrapping.
https://uk.farnell.com/c/tools-production-supplies/tools-hand-workholding/wire-wrap-tools-pencil
https://uk.farnell.com/ok-industries/r-30-tri/wire-wrap-wire-50ft-30awg-copper/dp/7333675
Wire wrapping is useful when things don't fit nicely on a breadboard, and changes can be made quickly without soldering.
Here's a RPi4 project with an LCD running on battery power.
Before I make an etched circuit board, I usually solder it up on a Vectorboard.
https://uk.farnell.com/vector-electronics/4614/pc-board-epoxy-glass-composite/dp/2850710
If you have 1206 size surface mount components, they fit nicely between the 0.1in pads.
  • colporteur
    colporteur over 4 years ago
    I haven't done a wire wrap connection since 1996. Terminating 250 pair cables in MDF frames. 26 minutes best time to complete.  I wish I still had my employer's tools. It was easy to make connections.
