Cool LED Display
  • Cool LED Display
Cool LED Display
Blog DIY LED Ferris Wheel
Join Cool LED Display to participate - click to join for free!
  • Author Author: dixonselvan
  • Date Created: 21 Dec 2017 6:50 AM Date Created
  • Views 7332 views
  • Likes 10 likes
  • Comments 9 comments
  • ardintermediate
  • arduino_projects
  • leddisplaych
  • arduino_classic
dixonselvan
dixonselvan
21 Dec 2017
Holiday's are really fun when we decorate our place with lights and stars. LEDs are mostly used for this purpose. I have made a DIY video series for a decorative, fun LED Ferris Wheel. Try one for this Christmas!
Required Materials [with links to buy]:
  1. Metal Mechanix 5
  2. Jackly Screw Driver set
  3. DC Motor
  4. Jumper wires
  5. LED
  6. Drill Chuck
  7. Wire connector
  8. Arduino Uno/ Mega
  9. 9V Battery, battery connector  and USB Cable (for Arduino)
  10. Scissors, double-sided tape and insulation tape
This will also be my submission for Cool LED Display
Code [Arduino]:
GitHub - Click Here
int ledOuter = 12;
int ledOuter1 = 8;
int ledInner = 13;
void setup() {
  // put your setup code here, to run once:
  pinMode(ledOuter, OUTPUT);
  pinMode(ledOuter1, OUTPUT);
  pinMode(ledInner, OUTPUT);
  pinMode(A1, OUTPUT);
void loop() {
  // put your main code here, to run repeatedly:
  digitalWrite(ledOuter, HIGH);
  digitalWrite(ledInner, HIGH);
  digitalWrite(ledOuter1, LOW);
  delay(10);
  analogWrite(A1, 255);
  delay(10);
  digitalWrite(ledOuter, LOW);
  digitalWrite(ledInner, LOW);
  digitalWrite(ledOuter1, HIGH);
  delay(10);
  analogWrite(A1, 100);
  delay(10);
Making the Frame:
Adding Electronics components in the Wheel:
Fun in the dark:
Let me know in the comments section for suggestions or queries.
    jw0752 over 8 years ago +4
    This project shows how much fun can be had with even simple ideas. This is a great inspiration to those who are looking for projects that will help them learn electronics. I bet you could wire up a coil…
  • dixonselvan
    dixonselvan over 8 years ago in reply to jw0752 +4
    Thank you jw0752 Believe me or not, I too had the same thought to power the LEDs through induction. Maybe soon I will try to bring out a more featured version of this current model. Dixon Selvan
    mcb1 over 8 years ago +3
    Simple idea. What does the Arduino do as it seems that the LEDs were simply static in the video. Mark
    This project shows how much fun can be had with even simple ideas. This is a great inspiration to those who are looking for projects that will help them learn electronics. I bet you could wire up a coil of wire at the ends of the ferris wheel spokes that pass by a neodynium magnet. This generated voltage could flash LEDs without having to have an Arduino and power mounted to the wheel.
  • dixonselvan
    Dixon Selvan
