Electronic Art
  • Electronic Art
Electronic Art
Blog Exploded View
Join Electronic Art to participate - click to join for free!
  • Author Author: jw0752
  • Date Created: 15 Jul 2020 2:22 AM Date Created
  • Views 6448 views
  • Likes 13 likes
  • Comments 18 comments
  • exploded_view_sculpture
  • electronicartch
Exploded View
jw0752
jw0752
15 Jul 2020
     For some time I have been toying with the idea of creating an electronic sculpture out of a circuit board by creating a 3 dimensional exploded view of the components raised from the board. Today I finally got inspired and built the project with this circuit board.
This is a circuit board from a Dental Composite Cure light. Dental composite is a white putty like plastic that is used to fill cavities. Once the dentist has the composite in the proper position a high intensity light is applied and the plastic goes through a process called polymerization by which it hardens. This board controls the power and timing that the light is applied. I have several of these boards and they are the right size so they made a good candidate for my Exploded View sculpture.
The first step in the process was to strip the board of components.
The next step in the build was to begin to return each component to a position above the place where it was originally mounted. I used various gauges of brass wire to bring the components up off the board. I used a heavier gauge wire for the larger components and around the edge of the board where the board would be more vulnerable to wear and tear. The idea was to raise the components into a spherical pattern above the board giving the appearance that they had all been lifted from the board by an explosion. The components at the center of the board were raised higher and the ones near the edges were raised less but placed at more of an angle to the board. Here is a picture of the finished sculpture:
The second picture shows the original board in the foreground with the exploded board in the background.
This view from the side gives a little perspective on how the components form a shell above the board.
However, it is very difficult to take a picture that shows the proper perspective on the sculpture so I have also taken a brief video to show the 3D effect better:
The Covid 19 has afforded me a lot of extra free time to play in my shop and explore new ideas. This project has crossed my mind several times in the past but the seven hours it took to put it together were always too high a price to pay until today. It seems I like to work with electronic components even if the end result is not functional electronics.
Thanks for checking it out.
  • fmilburn
    fmilburn over 6 years ago in reply to jw0752 +6
    John, if you haven't watched the talk below by Mohit Bhoite I highly recommend it. I was present when this video was made and he gives a good description of how he does free form electronic sculpture.…
  • aswinvenu
    aswinvenu over 6 years ago +5
    Nice concept and really creative John!
  • fmilburn
    fmilburn over 6 years ago +5
    So cool John. I wonder what the dentists would think. Or even better someone knowledgeable about electronics if a dentist was about to use it on them
    genebren over 6 years ago
    John,
    Very cool artwork/project!  It really does look as if it is all exploding off of the board.   For your next project you could ditch the PCB all together and build a cube shaped object where the parts are wired together in space.  Sort of a borg cube.
    Well done!
    John,
    Well done!
    jw0752 over 6 years ago in reply to genebren
    Hi Gene,
    That is an excellent Idea and it should be a working circuit as well. I remember how we used to make decorations by winding starch soaked string around a balloon and then popping the balloon after the string had dried. If a square structure could be found so that the electronic circuit could be constructed on it and then the structure removed just like the balloon was removed it would make a cool item. I will think on this. If anyone else has an idea of how to do it please feel free to take the idea and run with it.
    dougw over 6 years ago in reply to jw0752
    You could make square walls by melting some wax which might hold together well enough to build something before you melt them away again.
    I think it would be easier to make a frame from heavy gage wire and use strips of duct tape to hold things while they are being soldered.
  • fmilburn
    Mohit Bhoite - Building Free-Formed Circuit Sculptures
    Below is a simple example of his work:
    VU Meter
    • Vote Up +6 Vote Down
    jw0752 over 6 years ago in reply to fmilburn
    Hi Frank,
    Thanks for the link to Mohit Bhoite's talk. It was full of new ideas and techniques. I really hope it inspires a bunch of the guys to make something and enter the Electronic Art contest.
  • fmilburn
    I have really been wanting to make something but everything is still in storage from my move. I hope to be back in business by August.
