Fighting Germs
  • Fighting Germs
Fighting Germs
Blog UV LED Sterilization Lamp
Join Fighting Germs to participate - click to join for free!
  • Author Author: ninjatrent
  • Date Created: 8 Apr 2020 10:13 PM Date Created
  • Views 2094 views
  • Likes 9 likes
  • Comments 6 comments
  • fightinggermsch
ninjatrent
ninjatrent
8 Apr 2020
Fighting Germs
Enter Your Electronics & Design Project for a chance to win an $200 Shopping cart of product!
Project14 Home
Monthly Themes
Monthly Theme Poll
This a demo of a UV LED Sterilization Lamp. The purpose of this device is for safe storage of PPE or other items. With shortages of PPE, it is imperative that we develop means for safe and sterile reuse of what is available.
*Warning!! UVC Wavelength Light is recommended!!
*This project is a FAIL! Do not use UV/UVA 400nm LEDs!!
*UV/UVA wavelength not effective at sterilization of viruses. Only use exact recommended UVC Wavelength!!!
https://en.m.wikipedia.org/wiki/Ultraviolet
UVA/UV 400nm LEDs have been soldered to an Adafruit Perma-Proto Breadboard. There's a 100 ohm resistor connected to each LED ground. Power is supplied by a 5V 2A power supply with a barrel- type plug. This circuit is based from a tutorial provided by Adafruit and written by Becky Stern.
https://learn.adafruit.com/uv-manicure-lamp/overview
The temporary enclosure was made from foam board and duck  tape.
Please remember that UVC Wavelength is recommended. This project is only a demo.
Trent
    jw0752 over 6 years ago +5
    Hi Trent, This is a nice innovative build. Did I understand that the light produced is UVA? UVA may not have the energy necessary to kill most pathogens. UVC with wavelengths between 200 and 300 nm is…
  • ninjatrent
    ninjatrent over 6 years ago in reply to ankur608 +4
    Hello Ankur Verma, Thank you for viewing this project. It's with great hope that these projects we develop will help to end this pandemic. Yes sir. It's true that paper currency is a means of transmission…
    dubbie over 6 years ago +4
    Looks like a good project. But now we need some method of measuring the UV to see how powerful (?) it actually is, and we would also need to know how powerful it needs to be to actually kill the germs…
  • ninjatrent
    ninjatrent over 6 years ago in reply to dubbie
    A UV sensor would give a level of intensity. I don't have one unfortunately. I barely had the parts to complete. Used the last of my 100ohm resistors.
    According to the datasheet: Forward Voltage: 3.4V typical @ 20mA.  Maximum Forward Current: 25mA (20mA recommended)
    They could probably handle being pulsed at a higher voltage.
  • ninjatrent
    ninjatrent over 6 years ago in reply to jw0752
    Hi John,
    Thank you very much. The LEDs are reported to be UV/UVA 400nm https://www.adafruit.com/product/1793  . I have considered the addition of reflective Mylar to the inside of the box. Thank you for bringing it to attention that the UVC spectrum is recommended. I leave my mask in overnight and when not in use. This is a extra measure on top of sterilization with 91% iso alcohol and diluted bleach (not at same time). Now wondering if these UV/UVA LEDs are in anyway effective in killing the virus.
    Trent
    Looks like a good project. But now we need some method of measuring the UV to see how powerful (?) it actually is, and we would also need to know how powerful it needs to be to actually kill the germs/microbes. I wondered whether pulsing the UV LEDs at a much higher current might create more germ killing power? The average power might be the same but the pulsed power might be more effective. Difficult to know.
    Dubbie
    Hi Trent,
    This is a nice innovative build. Did I understand that the light produced is UVA? UVA may not have the energy necessary to kill most pathogens. UVC with wavelengths between 200 and 300 nm is what I have seen recommended for killing germs and viruses. Since it is the direct radiation that kills the pathogen it might be a good idea to line the box with aluminum foil with the shiny side acting as a mirror. This will allow the light to bounce around and get into cracks and crevices of the item you are sterilizing.
    • Vote Up +5 Vote Down
  • ninjatrent
    Hello Ankur Verma,
    Yes sir. It's true that paper currency is a means of transmission for many pathogens. I have sanitized the last few paper bills in iso alcohol before they were spent. Thankfully I'm out of paper currency. Unfortunately I'm also out of digital currency.
    We will get through the tough times.
    Trent
