Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog 2D xmas tree pcb art (components INSIDE the pcb)
Join Merry Boxes & LEDs to participate - click to join for free!
  • Author Author: designer2k2
  • Date Created: 5 Jan 2019 8:49 AM Date Created
  • Views 5090 views
  • Likes 13 likes
  • Comments 15 comments
  • gimp
  • kicad
  • merryboxesledsch
  • xmas 2018
  • pcblayout
  • github
  • holidayspecial19ch
  • xmas lights
  • xmas_tree
  • inkscape
  • github_repository
designer2k2
designer2k2
5 Jan 2019
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Project14 Home
Monthly Themes
Monthly Theme Poll
Hello,
my xmas gift this year, a 10x10cm pcb xmas tree image
2D xmas tree animation
all the components are inside the pcb, the overall height is only 1.6mm image
Castellation is used to make the connections:
CastellationCastellation with pcb
The pcb itself is using pcb art technique to give the shape of a tree covered in snow and some snowflakes and ball ornaments.
To help making the programm for the ATtiny a helper website is made to make the led addressing easier:
https://designer2k2.github.io/2d-xmas-tree/
xmas tree programming website example
All files including the KiCad project is hosted on GitHub: https://github.com/designer2k2/2d-xmas-tree
And to help with assembly a video: (in german, with english captions, turn them on)
    genebren over 7 years ago in reply to ntewinkel +5
    Nico, The price points on microscopes (stereo included) are all over the map. There are toy-like models (very cheap optics) available for under $100. There are inexpensive models available for $200 - …
  • designer2k2
    designer2k2 over 7 years ago in reply to dubbie +5
    Yes they are not cheap, this is the exact scope i have: https://www.ebay.de/itm/SB-1902-U-Euromex-StereoBlue-Bino-Zoom-Stereo-Blue-Schwenkarm-Mikroskop/231551764715 with the 0,5mm Barlow addon lens to…
  • designer2k2
    designer2k2 over 7 years ago in reply to dubbie +4
    thanks! Yes, i consider myself a hobbyist, and have done all that at home I use a stereo zoom (trinocular) microscope with a boom stand holding it over the workbench. The video above was mostly shot trough…
    dubbie over 7 years ago
    A great Christmas decoration. Very impressive soldering of surface mount components. I think I have to much hand shake to be able to do it. What sort of stereo microscope did you use? Is it something that could be reproduced by a hobbyist at home? Did the PCBs come with the silk screening already on?
    Dubbie
  • designer2k2
    thanks!
    Yes, i consider myself a hobbyist, and have done all that at home image
    I use a stereo zoom (trinocular) microscope with a boom stand holding it over the workbench.  The video above was mostly shot trough it with the camera attached on the 3rd output while i was looking trough it.
    It really helps a lot, your head can be rest against it, gives a very stable field of view. This makes soldering or working on small things easy.
    But i´ve done this a long time also with just a magnification lens on a 3rd hand, doable, but less fun...
    The PCB´s look delivered exactly as shown above, follow this Link to go directly to this PCB´s at dirtypcbs: DirtyPCBs.com
    dubbie over 7 years ago in reply to designer2k2
    Stephen,
    I had a look at the stereo microscope. A bit too expensive for me I think. I'll have to stick to pin-thro-hole components I think.
    Dubbie
  • ntewinkel
    ntewinkel over 7 years ago in reply to dubbie
    Hehe I was just wondering about price points on those too!
    I've done some smd soldering. using the paste it's doable even without magnifiers. I bought a 50 cent kit off AliExpress just for trying it out image
    I'm not sure I have the eyesight or steady hands to be able to pull off the castellation technique Stephan is using though! I think, Stephan, you might have a future in brain surgery image
    I was doing a little bit of soldering using the 3rd hand with magnifier last night, but nearly every time I do that I end up melting some plastic on the 3rd hand! oops. I'm thinking of maybe trying stronger reading glasses, or those on-glasses magnifiers like the dentists use.
    -Nico
    Nico,
    The price points on microscopes (stereo included) are all over the map.  There are toy-like models (very cheap optics) available for under $100.  There are inexpensive models available for $200 - $300 and higher quality instruments that can be more that $1000.  When I was looking for a microscope for my soldering needs, I searched on E-bay and found a very nice, used one (older Nikon). If you buy used, be careful and be patient and you will find a reasonable buy.
    It helps to have a variable magnification, in the range of 5x to 20x (mine is almost always set to 5x), lighting is important (I built a nice LED light ring for mine).  A boom stand would be nice (I still do not have one and some board sizes to not fit well under the scope).
    Here are some sample items:
    https://www.newark.com/kern/ose-416/stereo-microscope-binocular-1x/dp/58AC3542
    https://www.newark.com/kern/osf-438/stereo-microscope-binocular-1x/dp/58AC3544
    Gene
    • Vote Up +5 Vote Down
  • designer2k2
    Yes they are not cheap, this is the exact scope i have: https://www.ebay.de/itm/SB-1902-U-Euromex-StereoBlue-Bino-Zoom-Stereo-Blue-Schwenkarm-Mikroskop/231551764715  with the 0,5mm Barlow addon lens to get 160mm working distance.
    Its a bit modded with some 3d printed parts, for example a adapter to hold ikea lights: https://www.designer2k2.at/en/mods/elektronik/130-3d-printed-microscope-light-adapter-for-ikea-jansjoe
    (cheap and the most flexible light you can get)
    But its well worth it, and with some patience there are sometimes used scopes around (but most people never sell them again...)
    Basically you are looking for a stereo zoom microskope with around 0,7 - 4,5 magnification and 10x/20mm oculars and 100mm working distance. That results in a magnification from 7-45.  Then you attach a x0.5 lens and your working distance increases to around 150-160mm and your magnification drops to ~3-25  (thats not so exactly 0.5).
    In the video above you can see what this results in terms of field of view. It goes nice wide but can also zoom in to a single solder point. Where the 160mm distance gives a lot of room to solder.
    And if needed, unscrew the 0,5 and you have a very high magnification, usable for inspection of very fine details.
    There are some extensive discussion out there on what scope and so on, nearly every big brand has one with about exactly the specs from above.
    The only thing i cannot recommend are this USB-Webcam-Display things, i had one, there is no improvement against a magnification lens on a 3rd arm, it just looks fancy.   If, then you want to go for the stereo thing image
  • designer2k2
