Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog JackBox # 5 : Adding Some Festive Sound
Join Merry Boxes & LEDs to participate - click to join for free!
  • Author Author: dubbie
  • Date Created: 8 Jan 2019 6:15 PM Date Created
  • Views 1899 views
  • Likes 8 likes
  • merryboxesledsch
  • holidayspecial19ch
  • audioplayback
dubbie
dubbie
8 Jan 2019
Merry Boxes & LEDs
Enter Your Project for a chance to win a Maker Tool Kit, an Oscilloscope Grand Prize for the project that brings the Most Joy to the Heart, and Gift to Gives!
Project14 Home
Monthly Themes
Monthly Theme Poll
Having added a few LEDs to the Jack in the Box I decided to see about providing some festive sound track. As I indicated in the first Blog I did find a recordable birthday tag which I hoped to use, so I located this and removed it from the cardboard cover. After a close inspection it appears that the buttons used to record and playback audio are simple mechanical push-to-make contacts. The open circuit value is 2.4V and the closed value is 0V or ground. The sound controller itself seems quite sensitive and will start the record playback on almost any voltage change. I did have a similar tag some time ago that I was using for something else which had some long wires soldered to the switches and these would sometimes be activated by central heating boiler powering up. It was quite scary/weird being in my office and occasionally for no apparent reason it would start to play back, especially as I had recorded 'Hello, is anybody there' in a creepy voice.
The Arduino I am using is a 5V Nano. I tried connecting a digital output from the Nano directly to the switch input using a resistor to drop the voltage, having also connected the two ground voltages and this seemed to work well. So I wired everything together and instantly realised that I had performed the tests with the power to the Arduino turned off as it ran at double speed. So much for trying to be careful. It did make for some interesting voice affects but I thought it might stress the tag and as I only have one this didn't seem like a good idea. So I replaced the resistor with a small potentiometer set half way, to drop the 5V output voltage of the Nano to about 2.5V and this worked satisfactorily. The results can be seen and heard in the video below.
You might also be interested to know that I used some more of the LEDs salvaged from the bathroom vanity mirror to provide background lighting during video. I think it works OK and much better than the table lamp I have previously used.
Dubbie
    dubbie over 7 years ago in reply to 14rhb +2
    Thanks for your comment. I'm not sure where the urge for me to recycle stuff comes from. I usually prefer to buy brand new so I know it works, but sometimes, it's just more fun to take something apart…
    genebren over 7 years ago +1
    It looks like everything is coming together quite nicely. Good luck on finishing up your project! Gene
  • 14rhb
    14rhb over 7 years ago +1
    There is something satisfying about mashing some existsing salvaged electronics to a better known setup (eg your Arduino) - great work and nicely explained so others can replicate. Rod
  • 14rhb
    Rod
  • 14rhb
    Rod
    Thanks for your comment. I'm not sure where the urge for me to recycle stuff comes from. I usually prefer to buy brand new so I know it works, but sometimes, it's just more fun to take something apart and put it back together in a different. I took a petrol powered lawnmower apart once as an exercise in reverse engineering. I was very sad when they wouldn't let me start the re-assembled machine. Something to do with health and safety.
    Dubbie
  • 14rhb
    14rhb over 7 years ago in reply to dubbie
    ....they wouldn't let me start the re-assembled machine
    That is a shame as it would have been a really good exercise in making final checks, priming the system etc. and prevented you getting that awesome feeling of satisfaction when it started again.
    ps: keep up the recycling/repurposing where possible.
    Rod
