Merry Boxes & LEDs
  • Merry Boxes & LEDs
Merry Boxes & LEDs
Blog JackBox #6 : The Completed Article
Join Merry Boxes & LEDs to participate - click to join for free!
  • Author Author: dubbie
  • Date Created: 9 Jan 2019 5:27 PM Date Created
  • Views 5076 views
  • Likes 16 likes
  • Comments 17 comments
  • merryboxesledsch
  • holidayspecial19ch
  • leds.
  • buildapresentch
dubbie
dubbie
9 Jan 2019
Having completed adding the sound in my last Blog I decided to improve the LED part a little bit. I took three of the LEDs white wooden snowflakes shapes and fixed them to the front and sides of the box. Rather than just these three LEDS on and off I decided to fade them on and off. To do this I just connected the three LEDs in parallel and then the positive (the anode) to the +5V from the Nano and the negative (the cathode) to the D5 output of the Nano. The LEDs will all come on when D5 is driven low. To create the fade on and off effect I used pulse width modulation implemented as next for loops, as illustrated in the code fragment below. I used a function just to make it tidier. The value input into the function controls the maximum brightness achieved by the LED, which also controls the frequency of the LED slowly pulsing.
void pulse_WHITE(int brightness)
int move_index, LED_index;
   for (move_index = 1; move_index < brightness; move_index++)
        for (LED_index = 0; LED_index < LED_speed; LED_index++)
           digitalWrite(LED1, LOW);
           delayMicroseconds(move_index);
           digitalWrite(LED1, HIGH);
           delayMicroseconds(252- move_index);
          } /* for */
      } /* for */
    for (move_index = brightness  ; move_index > 0; move_index--)
          } /* for */
      } /* for */
} /* pulse_WHITE
I added this to the Nano programme, adjusted when the sound should start playing back the recorded audio and tidied it up as best as I could. Below is the final video of the whole thing. I decided to add some clockwork Father Christmasses and Reindeers to provide that little bit extra enhancement and merriment(!).
It's been fun but I'm glad it's over now as the constant tuneless recorded singing was beginning to drive me mad!
Dubbie
    DAB over 7 years ago +6
    Fun project for the holidays. Easily replicated for any specific holiday or event you want. DAB
  • ntewinkel
    ntewinkel over 7 years ago +5
    So cool! I like that you hit all the targets: it's merry, it's a box, it has LEDs. The Santas and reindeer added a total bonus to complete the effect -Nico
  • three-phase
    three-phase over 7 years ago +4
    Good to see the project finished Kind regards
    genebren over 7 years ago
    Very nicely done!  You worked through your issues and you added some playfulness to boot.  It almost felt like Christmas all over again.
    Gene
    Gene
    dubbie over 7 years ago in reply to genebren
    Gene,
    I do try to deliver what I have said I would do. Too many times in the past I've not quite achieved that and it seems as if it is not how much you actually achieve that is noted, but the tiny amount you couldn't quite manage. I try not to over-promise but I do sometimes get carried away with the exciting possibilities of what could be done.
    Dubbie
