NanoRama
  • NanoRama
NanoRama
Blog Digital Protractor
Join NanoRama to participate - click to join for free!
  • Author Author: niravjadav
  • Date Created: 19 Jun 2020 5:53 AM Date Created
  • Views 1744 views
  • digital
  • diy
  • nanoramach
  • idea
  • gyroscope
  • protractor
  • diy project
Digital Protractor
niravjadav
niravjadav
19 Jun 2020
Digital Protractor
- An Interesting DIY Idea ..
What if Your Ruler Scale converted in to Protractor .....
This Project is all about convert an ordinary ruler in to Smart Ruler having a extra feature of measurement of Angle.
Step 1 :- What you need
other handy tools -
Step 2: How It Works..
Heart of this module here is ARDUINO PRO MINI , It is use here to handle all external Peripherals like ButtonPanel, OLED display and Gyroscope(MPU6050).
  • To Power up this module here we use 3.7v Lippo Battery which is capable to deliver upto 180mAH,to charge battery here TP4056 module used via 3pin Toggle Switch.
  • Here Gyroscope send raw data to Pro mini, by mathamatical calculation Arduino Pro mini find YAW ANGLE from it based on movement of scale(ruler) on which this module is sticked.
  • OLED display here use to display current angle with respected to taken refrence using button_2.
  • OLED and Gyrscope(MPU6050) use I2C Protocol to interface with Arduino Pro MINI.
Lets understand Button function:
Button_1 : Press to enter into Angle mode to measure angle.
Button_2 : for taking Reference form which you have to measure angle.
Button_3: for calibration of Module (In case of Temperature and humidty variation).
for better understanding see video of Working of Digital_Protector .
Toggle Switch :
Toggle Switch has two mode ON and OFF mode.
ON mode: To turn on module and measure angle.
OFF mode : 1) To turn off module
2) To charge module
[ NOTE: Don`t use ON mode for Charging It may Damage Your Hardware. ]
Step 3: Circuit Building
  • Make all connection as per shown in circuit daigram with compactness because we are fitting all circuit in plastic Box in order to make module very compact.
  • One thing is you need to take care about Yourself how to fit all electroincs stuff in plastic box because here I didn`t mention anyware how to fit all stuff in box.
  • [ Note : So, make connection as small as possible in to order to fit in the Plastic Box.]
Step 4: Firmware Uploding ...
> Connect arduino NANO to host computer
> open Sketchbook of firmware in Arduino IDE
>Select COM port.
> Upload Code and Play with Digital Protector.
[Note : Keep all files in one folder as a scketchbook in order to sucessfully code uploading.]
Future Scope :-
As Arduino is Open source[thanks !] so developed a board where all connection is on board you have to just solder it and play ! yayy...
Thanks for Reading !...
-Nirav
DIGITAL_PROTECTOR.rar
  • niravjadav
    niravjadav over 6 years ago in reply to dubbie +2
    Thanks for Reading ! About Calibrate there are specific algorithm which calibrate gyro raw data accroding to surrounding temp and varios other factor for manual calibartion 3rd button is for that purpose…
    dubbie over 6 years ago
    Nirav,
    This is a very interesting project and I like that you have completed it all and put it into a box. Did you perform any measurements to calibrate your system to see how accurate it is?
    Dubbie
  • niravjadav
    About Calibrate there are specific algorithm which calibrate gyro raw data accroding to surrounding temp and varios other factor for manual calibartion 3rd button is for that purpose only.
    Hope I answered your query.
    -Nirav
  • niravjadav
    -Nirav
  • Andrew J
    Andrew J over 6 years ago in reply to niravjadav
    Very interesting - did you measure its accuracy against an actual protractor?
    dubbie over 6 years ago in reply to niravjadav
    Nirav,
    Have you tried calibrating it against a manual protractor?
    Dubbie
