Off-the-Grid
  • Off-the-Grid
Off-the-Grid
Off-the-Grid Blog Ham Radio Off-the-Grid "Go Box" and Solar Charging System
Join Off-the-Grid to participate - click to join for free!
  • Author Author: rsc
  • Date Created: 3 May 2023 1:53 PM Date Created
  • Views 15226 views
  • Likes 12 likes
  • Comments 7 comments
  • offthegridch
rsc
rsc
3 May 2023
For off-the-grid communications, a radio "Go Box" is sometimes a good option.
In places with no cellular coverage, your only options for communication are radio or satellite.
I chose to build a Go Box using an ICOM IC-2730A mobile transceiver since it can be used as a dual cross band repeater, or a full duplex satellite communications radio.
I also have a 100W solar panel that came with a couple of 12V lamps and a battery charger interface that works well with the Go Box.
I have 2 batteries for the system, a 12V 7.5AH sealed lead battery for most days, and a 12V 20AH LiFePO4 for extended use.
I've used the system for Ham radio winter and summer Field Days for the past two years.
http://www.arrl.org/field-day
I've even talked to the International Space Station using the Go Box with an Arrow II Dual Band Yagi antenna.
The Go Box still needs some work - I have a few accessories to add, some USB charging ports, and some other 12V charging ports. Stay tuned for updates....
  • dang74
    dang74 over 3 years ago +1
    I love the way the radio looks in its case... so cool that you communicated with the International Space Station.
    DAB over 3 years ago +1
    Nice build. You can now pick up and go to a remote location with a backup plan when the batteries get low.
  • rsc
    rsc over 3 years ago in reply to DAB +1
    Yes, and I also have an even smaller setup that fits in a backpack using a dual band handheld transceiver, a 30W linear amp and the Arrow yagi antenna. I think I need to make something cool that will fit…
  • dang74
    dang74 over 3 years ago in reply to robogary
    That's a nice looking heavy duty case as well.
  • robogary
    robogary over 3 years ago
    Nice job chatting with ISS.
    Your go box is a nice pelican case, all protected and cozy.
    My vision was to build a go box that could be used as a base station, and with a quick unplug of an outlet and antenna, close the covers, I could be on my way, including the station PC.
    I was thinking a Multicomp pro flight case could be a start to that concept https://www.newark.com/multicomp-pro/555-19502/shallow-abs-19-rackmount-flight/dp/48Y8204
    but need to engineer shelves and a way to bolt down the equipment to those shelves.
    Have you seen others use that approach ?
  • dang74
    dang74 over 3 years ago in reply to rsc
    Incredible.  And I just scanned through his bio.  He accomplished quite a bit even before going to space.
  • rsc
    rsc over 3 years ago in reply to dang74
    I was only expecting to talk via the ISS repeater, then one of the crew (Kjeil Lindgren) came back to me on the radio - that was fun.
    www.nasa.gov/.../biography
  • rsc
    Yes, and I also have an even smaller setup that fits in a backpack using a dual band handheld transceiver, a 30W linear amp and the Arrow yagi antenna.  I think I need to make something cool that will fit on the kayak this summer.
