Off the Shelf
  • Off the Shelf
Off the Shelf
Blog Fireworks Simulation with Optical Fiber Cable (OFC) Day 8 final post.
Join Off the Shelf to participate - click to join for free!
  • Author Author: colporteur
  • Date Created: 28 Aug 2021 11:27 PM Date Created
  • Views 3121 views
  • Likes 9 likes
  • Comments 8 comments
  • offtheshelfch
colporteur
colporteur
28 Aug 2021
Mounted the controller breakout board (i.e. perf board) and routed the RGBLED OFC cables through cable holders. Cable holders are just pieces of heat shink tubing, super glued to back board. In addition mounted the power supply assembly and routed power cables and input/output cables.
The fireworks light display will be triggered by a button mounted on the layout. A scope creep request was presented to make the display unit portable. A two button fireworks triggering solution was needed. A button on the display panel is recessed (below voltage display segment in the picture) and is wired in parallel with the button that will be mounted on the layout. Either button pressed will trigger the fireworks sequence.
haircut1.jpg: cutoff strands flush to the panelimage
haircut2.jpg: one down two to goimage
haircut3.jpg: cutting strands flush with side cuttersimage
The optic fibre cable strands poking through the display needed a haircut. Using a pair of side cutters the strands were cut flush to the display panel. With all components mounted and a quick meter test to prove no shorts the display assembly was powered up. NO SMOKE!
Summary
The plan for this off-the-shelf project was to use an optic fibre cable lamp to create a model railroad layout fireworks light simulation. A series of blogs posts were created to document and track progress.  A short video to demonstrated the projects success is enclosed.
  • colporteur
    colporteur over 5 years ago +2
    Thanks DW. It was a luxury two weeks of retirement. Next week I have something scheduled for every day of the week. No playtime then:(
    dougw over 5 years ago +1
    Great project and you kept it on a tight schedule with daily blogs - kudos.
    DAB over 5 years ago +1
    Great job, now all you need to do is get some audio working behind it. DAB
  • robogary
    robogary over 5 years ago
    That is pretty cool addition to the RR - I could almost hear the crackling and booms. I enjoyed Asia in the audio background while listening for the crackling and booms:-)
  • robogary
