Op-Amp-a-Palooza
  • Op-Amp-a-Palooza
Op-Amp-a-Palooza
Forum I'm still struggling to apply my limited knowledge of op amps... so I've created a problem to solve... but need your help.
Join Op-Amp-a-Palooza to participate - click to join for free!
  • Replies 23 replies
  • Subscribers 39 subscribers
  • Views 5007 views
BigG
BigG over 4 years ago
I can follow along other peoples projects but it quickly becomes apparent that I do not fully grasp the fundamentals when I try and solve a problem of my own.
So here is my own problem I'm trying to solve, as shown below:
I have two scenarios. I think the first one is fairly easy, but it is knowing how to achieve the 2nd that is more challenging, especially if you wish to say use the same op amp and even the same circuit the 1st.
How does one go about this?
As per usual, I very quickly try and over-complicate matters... like when spotting these types... Transresistance amplifiers... and wondering whether I should/could use these...
Anyway, no doubt this is a very straightforward problem for the experts.
I look forwards to getting some tips.
Thanks.
C://
  • beacon_dave
    beacon_dave over 4 years ago +7
    This might be of help ? 'Designing Gain and Offset in Thirty Seconds' https://www.ti.com/lit/an/sloa097/sloa097.pdf
  • scottiebabe
    scottiebabe over 4 years ago +6
  • beacon_dave
    beacon_dave over 4 years ago in reply to fmilburn +4
    More in-depth coverage in this book: Op Amps for Everyone https://www.elsevier.com/books/op-amps-for-everyone/carter/978-0-12-811648-7 The calculators don't appear to be on ti.com anymore but can be…
  • beacon_dave
    0 beacon_dave over 4 years ago
    • Vote Up +7 Vote Down
  • BigG
    0 BigG over 4 years ago in reply to beacon_dave
    Brilliant, I'll have a read through. Thanks.
  • fmilburn
    0 fmilburn over 4 years ago in reply to beacon_dave
    That is a really nice reference, it even has filtering with a single op amp.
  • beacon_dave
    0 beacon_dave over 4 years ago in reply to fmilburn
    The calculators don't appear to be on ti.com anymore but can be found here:
    Op Amp Applications by Bruce Carter - Op Amp Applications Specialist
    http://earmark.net/gesr/opamp/
    0 dougw over 4 years ago
    Good references. Figure 7 can be modified to use a pot to adjust the offset:
    R1 adjusts the voltage swing, R3 adjusts the offset.
  • BigG
    Using that document as my guide here are my design equations.
    Case 1:
    And same answer for Case 2... positive m & negative b.
    This moves us onto section 4 of design guide...
    This section then asks "Choose Rf (may be suggested on data sheet)"... ok then...
    Onto Farnell's website and... Operational Amplifiers - Op Amps: 7,260 Products Found!
    This may take a while...thankfully choosing "those in stock" narrows it down a bit (LOL). Now down to 1,691 Products Found!
    As I'm using a TI guide, how about a TI Op Amp... now down to 620... getting better.
    Assuming that I only need 1 amplifier... 250 Products Found.
    Now not sure... looking at the cheapest doesn't help matters as search criteria on website gives options like "supply voltage range".
    As I'm using a 3V3 MCU, I assume that's the value to use... Now down to 116 Products Found.
    So picking the first 3 on the list gives me... LMV821M5/NOPB, TLV8801DBVT, and LM741CN/NOPB
    The LMV821 and LM741 show Rf as R2, and show a typical value of 4.7k... so using that.
    Now I have two values for R1.
    The document then talks about tuning.
    Two options are given. One suggests tweaking R1 to compensate for errors and the 2nd option is to use a 2nd op amp.
    So now what... am I on the right track...
    ... ah I see Figure 7 has been suggested as another response... with some values... and using LM307
    Still, I would like to understand how one gets to that answer.
  • BigG
    0 BigG over 4 years ago in reply to dougw
    Brilliant. Thanks dougw
    I provided some detail of me working through that document. Kinda got stuck, but I appreciate your answer.
    I was hoping that my two options could be selected through software using same circuit, so not sure a resistor pot will work in this case.
  • BigG
    0 BigG over 4 years ago in reply to BigG
    It is interesting to notice, while searching for the right product, that there are quite a lot my 2 channel op amps available... is this to allow you to design a more accurate solution using one component as noted in the guide.
    0 Jan Cumps over 4 years ago in reply to BigG
    A few reasons: there is the immediate real estate advantage because dual and quad opamps take less space than 2 or 4 discrete ICs + their individual decoupling caps.
    It can also play in your advantage that they are often better matched than two single opamps of the same type.
    Disadvantage is often increased cross-talk.
    0 shabaz over 4 years ago in reply to BigG
    The op-amp guides are super-useful, but they address op-amps only, whereas your solution could involve other techniques in combination. But, more information is needed (e.g. what is the load, and is your stimulus AC (e.g. square wave or PWM) or will you want the output to work for DC too, and also do you wish the input to take values between 0V and 3.3V (e.g. DAC inside MCU) or is it a digital logic output? (this can affect the design, depends on if you wish to have a linear response, or not).
